My Ride Thread :) Artistic Or Not; Put Them On
  • 3 weeks later...
  • Replies 262
  • 3 weeks later...
  • 1 month later...
These are my 2 1971 Datsun 1600s. The black one was my first one and sports an L20B (2000cc), twin carby N/A motor. It should run in the 14 second barrier, though is off the road atm with a cracked head & stuffed radiator. The blue one is the most solid 1600 shell I've ever seen so I picked it up and I am turning it into a racecar/daily driver to compete in tarmac rallies.
  • 3 weeks later...
The difference with a burgandy r33 skyline side indicator lights
Normal orange side indicator lights -
With the nismo clear side indicator lights -
Also, 2nd set of pics with the clear indicator lights, thats the car fully cleaned & polished!
  • 3 years later...
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
