Item: 2 X standard GTR turbos from my R33 GTR
Item Condition: Good
Reason for Selling: Upgraded to GT-SS's
Price and Payment Conditions: $600ono
Extra Info: Shipping would only be $20 or so. Pickup Available. Unknown kms. Turbos are in good condition, never had a problem with them. Ran them at 1bar with no issues.
https://www.sau.com.au/forums/topic/98669-fs-r33-gtr-turbos/
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • Has anyone used or considered Hi-tech mufflers, Bourke St Darlinghurst? They were the cream of the crop in quality and workmanship when I had my turbo Forester They specialized in custom stainless exhaust systems, especially for Euro supercars
    • @PLYNX I can help source the OEM shit for you for less, slide into my DMs.
    • Don’t know if any one has noticed but there’s a few US spare parts companies that have purchased what seems like all the new old stock NISMO/Skyline parts and charging rich US dollars
    • Also, the cause of fuel spills and smells from the top of the tank is almost always the rubber hoses that are up there, not the tank seal.
    • 1. No, as you say you can remove the connectors and fuel lines. Before you do make sure you remove fuel pump fuse and crank the starter a few times to release pressure, and also loosen the fuel cap (just in case the tank is slightly pressurised) as it will pump out the lines otherwise 2. Not necessary but you are right, if it is the factory pump it is at risk of failing after 25 years....Changing it is not hard but potentially not trivial as you have to make sure you have the right pickup/sock for the pump to suit the tank, need to make wiring connections (crimped butt connectors would be fine) and have to mount/adapt the new pump in the right place in the cradle. Not impossible but don't start the job if you aren't confident. Also, the plastic nut that holds that seal in place can be really hard to remove. If you don't have a fuel nut removal tool it generally requires a big screwdriver or similar to bash the ring around a few times before you can get it by hand. Also the fuel lines can be very sticky on the tank lid fittings, hose removal pliers can help or if not twist the hose on the fitting (eg with linesperson's pliers) to break the seal before you try and remove it. Finally, mark the feed and return hoses so you don't put them on backwards and seal them with an m8 bolt to stop crap getting into the lines while working. Add a little grease in the threads of the plastic lid when you go to do it back up as a gift to your future self, and make sure you put it on evenly/not cross threaded.  Having said all that, most likely the lid just needs to be either tightened or removed and put back on without being cross threaded...the seal itself is usually pretty good.
