hi guys..
new poster here.
im currently looking around for a car for myself.
ive been looking at the 4 door R32 rb20det
seeming as my budget is limited, i have spotted some on firesport that have recently been imported.
i was told the compression test shows above 145 on all cylinders, and the car is in very good conition. what is the normal numbers for this motor?
im not that fussed about dents or scuff amkes inside the interior.... just want the engine to be reliable and without problems.
what should i look out for?
or should i stay away from them?
my budget is around 9k max... too low of a budget for this kind of car?
the reason i was choosing a 4 door, was to hopefully help with insurance premiums.. if it will make a difference at all...
any help would be appreciated
thanks
https://www.sau.com.au/forums/topic/98702-new-poster-wants-info-about-skylines/
i dont know if being a 4 door will make much of a difference if your buying a turbo skyline as far as insurance goes, are you a P plater?
If your budget is set to about $9000 it may not be the best idea to get a 32. They are reasonably old and if a problem pops up it could easily cost you another grand at least. It would probably be a good idea to not only go by what the seller is telling you about "how good condition the car is" and get it checked out by someone, like racv vehicle inspections. B4 i bought my r33 i was just about to get a "good condition 180" that turned out to be just about to fall apart.
And to answer the question about what to look for and what to stay away from...
check around all seals for rust, basic things such as quality of interior which may indicate how much the previous japanese owner cared about his car. Take the car for a drive yourself and drive through the gears slowy to see if you notice any unhealthy sounding vibrating or anything that doesnt feel right about the diff and gearbox. Check the exhuast to make sre it isnt blowing any wierd looking smoke, not just on idle, get someone to rev it too, should come out clear. also if you notice any little holes in the dash, that would indicate guages were attached once. if the car had guages it would also probably have had other mods that may have been taken off, thats a sure indication the car has been thrashed, this may not necessarily mean it will be a problem car but you need to be wary of it. also cheack for smash repairs. if the car has been in an accident even after panels have been fixed (often very poorly) the body may be bent so the car will never feel 100% right to drive.
There is obdviously heaps of other things i didnt mention so anyone else is free to add!
I can help with the insurance bit of your question. I use to work for an insurance company under 12 mths ago. As fas as insurance goes any import that has 2 doors OR a high pressure turbo is a grade 9. This is the highest grade and the only thing seperating you from paying the same premium as a porsche driver is the purchase price. If you were to get a 4 door non turbo skyline (which lets face it u might aswell buy a camry) then itll be a grade 5. This is the same as something like a new beetle. This is how the company i worked for operated. Other comanies may vary but i doubt it. Just before you buy get quotes for both.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
