Try using the search button.
Have you ever considered adding the "Try using the search button" to your signature, it seemes every second post of yours uses it? :D
hi all, i'm in the market for an r33, i was just wondering if i can ask some dumb questions like whats a stock gts-t run down the 1/4? how long does a stock turbo usually last? and if there is any common problems with em? if anyone can help it would be great thanks
Hi - welcome to the forums.
Stock 33s - depending upon the driver, track, condition of the car etc should be good for a 13-14 second 1/4 mile
Stock turbos are quite good, and will last a long time. The usual problem is that we all want more power, so as we increase the boost we risk damaging the turbo. Most people feel increasing the boost up to around 12psi (from a factory set 7psi) should be OK, but after that you reduce the life of the turbo.
As for common problems, there arn't really that many. Only ones I can think off are that the "Radius Rod Bushes"?? are often a little worn out when they arrive from Japan and need to be changed (not expensive) and that at 100,000km you need to change the timing belt (and its a good idea to do the water pump aswell) which isny the cheapest service (but not bad compared to other cars).
Common modifications usually include :
better exhaust (3 inch) from the turbo back
Front mount intercooler to replace the small factory one
Increase the boost - Bleed valves are cheap, but Electronic boost controllers do a better job.
After that you would consider aftermarket engine management such as a Power FC or other.
Now the power bug has bit hard, so you want to get a biger turbo, improve the fuel system (new pump and injectors) etc etc
The suspension and handeling of the 33's is quite good, so you dont need to modify it as soon as many other cars, but its worth considering a good set of tyres so you can use the power. Other mods often include a Hicas lock kit, Pineapples (to adjust the rear end geometry) and better quality brake pads to help you stop quicker (no real need to change the rotors unless you go for huge power)
Hope that is of some help.
https://www.sau.com.au/forums/topic/98725-turbo-rebuilds/#findComment-1797598
Have you ever considered adding the "Try using the search button" to your signature, it seemes every second post of yours uses it? :)
Nah not really. I prefer to say it.
Sometimes if im bored ill go an use it myself and post the results.
But most things you'll find, especuilly boost level for a stock turbo, you cant say thats probably not in the top 10 topics
https://www.sau.com.au/forums/topic/98725-turbo-rebuilds/#findComment-1797775
13s in a stock 33? maybe a GTR! But for a GTST in perfect working order stock at best you would get a 14.5, which for a car 10 years plus is really good, for example the new xr6t typhoons in motor magazine got a time of low 14s, so they are really good cars!
https://www.sau.com.au/forums/topic/98725-turbo-rebuilds/#findComment-1798678
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
