Hey ppls,
About to replace the front tyres on my car, due to them being excessively worn on the inside. This has been a problem since I got my car, so I'm wondering if I can get any tips on settings so I can avoid this in the future.
- Stock suspension, street use
- Whiteline adjustable swaybays (front and back) to be fitted next week
- Front: 17x8, Dunlop FM901s 235/45ZR17
- Rear: 17x9, Potenza GIII 255/40ZR17
Most recent alignment settings (Gordon Leven)
Rear Camber L -1'14"
Rear Camber R -0'47"
Rear Toe L +1.9mm
Rear Toe R -1.1mm
Front Castor L +6'53"
Front Castor R +6'26"
Front Camber L -1'21"
Front Camber R -1'11"
Front Toe L +0.7mm
Front Toe R +0.7mm
https://www.sau.com.au/forums/topic/98750-33-gtst-excessive-inner-wear/
Hey ppls,
Rear Toe L +1.9mm
Rear Toe R -1.1mm
Front Toe L +0.7mm
Front Toe R +0.7mm
Front tyres worn on the inside is usually either toe or camber, toe looks OK at 0.7 mm each side. So must be camber, I don't usually go over 1 degree on a road car. But 1.2 degrees static is hardly excessive, do you do a lot of freeway/highway driving?
Just to complete the picture, what are the heights on all 4 corner, centre of wheel to guard? It maybe a dynamic camber problem, not just a static one.
You really should do some adjusting of the rear camber, 1.1 on one side and 0.47 on the other is not so good. The standard adjusters should help in that regard. The rear toe needs correcting as well, has the HICAS been centred lately?
:P cheers :O
i had the same problem.. was wholy caster rods.. the more you corner hard, the worse the wear. Replaced bushes, been fine ever since.
Check the bushes if you haven't already. Look for cracks in the rubber, or fluid leaking out.
I am in an annoying situation with my suspension.
At the moment until I get my driveway fixed I have my rear suspension higher up then my front. (HKS adjustable) I feel like it would be pointless to get a camber kit or anything else till i lower the back to match the front.
Here are the numbers from a wheel and steering alignment done recently.
Rear Axle
Camber
before
Left before -1’21” after -1’24”
Right before -2’12” after -2’13”
Toe
Left before +6.5mm after +0.5mm
Right before +1.2mm after +0.3mm
Castor
Left before +6’33” after +6’33”
Right before +6’48” after +6’48”
Front Axle
Camber
Left before -1’40” after -1’11”
Right before -2’28” after -2’57”
Toe
Left before +7.68mm after +0.9mm
Right before – 10.5mm after +0.8mm
not sure new bushes or camber kit would help till I get my suspension how i want it?
Rear Axle
Camber
before
Toe
Castor
Front Axle
Camber
Toe
Well.........if it has 3 degrees of negative camber on the front (without any camber adjustment) then it's too low for decent handling, braking or traction. You have raised the back and it has over 2 degrees negative, that's also/still too low for decent geometry, traction, drive shaft angle and acceleration.
What are the centre of wheel to guard measurements? If much less than 350mm front and 340 mm rear then you really need to address that issue before you get into alignment products.
:) cheers :)
just to make it clear... I raised the bacck suspension long before I had the alignment done. The before is before the alignment the after is what settings and changes the aligner made.
he told me I had some really strange settings. strange = not good ?
Edited by noise
Yep, when you have them too low the suspension geometry gets very screwed up. The rear camber goes way negative (you have that), even the front camber gets excesive (you have that), the front toes outs (you also had that) and the rear toes in (yep you had that).
What you are seeing only the static readings, the dynamic readings are even worse.
Hence my question about height.
:) cheers :)
PS; You shoud see what it does to the driveshaft angles.
Edited by Sydneykid
sorry to hijack the thread.
sydneykid whats causing all these crazy numbers? because its lowered at the front?
if its all lowerred and I got a camber kit at the front would that fix it?
I really need the centre of wheel to guard heights on all 4 corners to give a definiitve answer. It's a vital bit of info.
:) cheers :)
approx 33cm on front and 35 cm on rear from centre of wheel to guard.
330 mm on the front......well that explains the excessive camber.
It really needs to go up 20 mm, to give it some geometry.
Then you can stick the camber bushes in and set it up properly.
350 mm at the rear with that sort of camber would indicate that there must be some worn bushes. Either upper arm (rear camber bushes will fix that) and/or maybe subframe (the rear subframe bushes will fix that). You can then come down 10 mm and still have reasonable geometry there.
These are the bits that you will need;
KCA331 Caster Kit $110.00
KCA348 Front Camber kit $272.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
Total is over $500 so delivery is free on the Group Buy.
The front and rear toe will have to be adjusted after the bushes are installed and the caster and cambers are set up correctly.
:) cheers :(
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
