As the topic says, I have a belt depicted which has slipped 1 groove/tooth. The belt is shown in the picture below. It is this part/cam which has slipped, but the other part/cam which it connects to, is in place, creating an angle in the belt.
The top right pic shows how the belt should be in place and the bottom shows the slip on my car.
Im pretty worried the tension created may break the belt, which will be disastrous.
Questions are how do I shift it back in place safely? Also do you think the situation needs adressing asap?
Edited by Are_thirty_two
https://www.sau.com.au/forums/topic/98793-a-belt-has-slipped-a-groove/
It looks like your power steering belt? Loosen up the power steering pump and slide it back, put belt back into position, slide pump back, tighten.
At worse, if it snaps you'll lose power steering. It won't damage the engine.
Your timing belt isn't in the engine bay, its behind another cover - it sounds like that is what you're referring to.
if it was my car i would just take it to a mechanic straight away and get it sorted, not worth risking. i believe if the timing belt fails / comes off / snaps then you crown the pistons and kill them = $$$
Have you had the crank end float looked at?
Its common if you have excessive crank endfloat to throw belts the way you are. My old man owned an EA falcon that did the same, as did a mate of mine who owned an ED falcon. Motor still appeared to run fine, no knocks etc.. It did require a rebuild before anything major occured.
my mechanic has been on holiday since christmas and i dont know when hell be back, thats why im asking here.
when you say rebuild, do you mean on the engine or on the crank end float?
how much did it cost your dad and mate to fix, and was it a big job or a one day job?
well if it was put on incorrectly as cubes previously mentioned, you can just take it off and put it back on properly. Check the belt for damage before you put it back on.
there are 3 bolts you need to undo to loose the tension and then remove the belt:
First is the long bolt, it's underneath and to the right of the PS pump, it goes in horizontally. you will probably have to remove a piece of intercooler piping to get to it. You have to loosen this bolt right up (don't actually remove it). The more room on this bolt, the further the distance of the pivot and the easier it is to remove the belt.
The second bolt is pretty much directly underneath the pump itself. you WILL have to attack it from underneath by removing the tray first. This bolt holds and secures the long bolt in place.
The third bolt is the pivot bolt. It's located behind the pump wheel.. There are holes in the wheel/pulley so that you can access the pivot bolt. Make sure that this hole lines up with the pivot bolt (by cranking the engine) before loosening the other two. The pivot bolt when loosened, allows the powersteering pump to pivot like a hinge.. you push it down and it sort of rollls inwards, loosening the tension on the belt.
I was young at the time but I do remember the mechanic grabbed a crow bar and attempted to move the harmonic balancer away from the motor towards the radiator.
If stuffed a little pressure you will see the harmonic balancer move away from the motor.. hence excessive crank end float, the harmonic balancer should not be able to be moved back and forth.
Edited by Cubes
Another thing is to make sure that the power steer pulley and the crank pulley are lined up correctly. it can be caused the the power steering pulley not sitting directly in line with the crank pulley.
Its not too hard to put the belt back on, but you also have to tighten up the belt again afterwards
This happened on my R33 as when I did the timing belt I left the power steer one a bit loose. It may be just that the belt wasnt tight enough. I tightened mine up and it hasnt done it again.
It's a fiddly job to adjust it. You need a small 10mm spanner to get in there and. You need to undo the centre cocking nut and ease off the adjustment bolt (you need many turns on this. A very small ratchet spanner would be the way to go. I was there for about 10mins on this one as the radiator gets in the way stopping you turning it much)
Reposition the belt on the pulley properly then tighen up the adjustment bolt and once adequate tension then tighten the centre locking nut.
Edited by benl1981
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
