  • Replies 120
Posted Images
OK guys, I have been told from multiple sprayers, mechanics and enthusiasts that VHT Caliper Paint is the best stuff for the job...
Problem is that their colour choices are quite limited and hard to find; good luck to you all - I'm going to CarPlus down in Mona Vale on Thursday maybe, will call a few of you to see if you're keen - I'll just get the receipt and you can fix me up later :D
G'day peeps,
I painted my calipers a couple of years back and I recommend that you use proper high heat caliper paint unless you want your calipers to peel after a few months and look worse than stock anyway. Also it wasnt the quickest job Ive done because quite alot of patience is needed in prepping your calipers before you paint them.
Make sure you bring heaps of degreaser and heaps of old rags to clean your brake dust off. With the actual painting youll need to do more than 2 coats for a good job otherwise the finish will look shit.
And you will need to wait till each coat dries for a good job. I had to put my calipers in my mates oven to get the paint fully solid, then i did it again the following night for the second and third coat to male it look perfect. If youve ever taken your calipers apart there are quite a few bits and pieces to them which you dont want to lose.
Once you done the second or third coat put the caliper back together and hook it up remember you will need to refill your brake fluid and re bleed your brakes otherwise you will have no brakes.
I dont want to put you off but it might be better doing this in a garage or a workshop because it does tend to get a bit messy, and you definitely dont want brake fluid on your body work it will eat the paint like acid.
I might come down and give you a hand if im not too trasshed from xmas celebrations.
Cheers :D
Michael
Im there of course :)
Will bring some newspapers also...
Though for the best effect we should take them off? but its a bitch ey?
Any mechanic's wanna come along? lol
we able to do it with them still on? cause re doing the break fluid and so on sounds like a fare hassel
Could I just ask if you guys are painting your calipers on or off your cars?. If I have time I'll come out and help but if I see one car on bricks I gonna steal its wheels and not give them back.
Neil.
Neil.
I think with the calipers on the car...
bad idea... they need to come off for a lasting job.. when i did mine a friend helped me and it took a while...5 hours roughly... but they still look damn good...there's a lot of cleaning involved... if you think getting the brakedust off yr wheels is bad..... you're in for a treat here.
Sure mate, the car's at the mechanic now getting pink slip. The wheels look good and my car looks drift spec cuz of the stock wheels on the back. Don't worry though, there has been no loss of traction.
I'll bring them to the day, where in Chatswood are we meeting?
I'm pretty sure degreaser is the way to go. They need to be pretty scmick before you paint them. I'll bring sandpaper too. I think the best way to paint them is to take the calipers off the discs and let them dangle off the brake lines so you don't need to bleed the brakes but can still paint the whole caliper
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
