The Horsepowerinabox.com GTR is up for sale!
This Low K's (25000), good condition V Spec 1999 GTR has all the gear.
It is Silver with the Jun Body kit (less rear wing... factory rear wing instead). Factory rims in gold. Killer 2.7 Jun stroker engine with a Trust T78 turbo kit. 1000cc sard injectors, HKS F Con V Pro ECU, Big cams, HKS Dragger exhaust, GTR intank, 044 secondary pump and Plenty of power....
It is still a good drivable streeter that performs well under 4000 and boosts up at 4500. I have it on 1.2bar for street cruising and it reportedly made 400rwkw at 1.2 on its last service.
It has a Nismo twin clutch that has just been freshened
Item:1999 V Spec GTR
Item Condition:Good
Reason for Selling:time for a change
Price and Payment Conditions:$85000 ono
Extra Info:plenty of JUN gear
Contact Details: Morrie at horsepowerinabox.com 0414780830 or email [email protected]
Edited by inabox
https://www.sau.com.au/forums/topic/98858-r34-gtr-for-sale/
oh is this the one that was on the front cover of Speed Magazine before? Nice ride
The intercooler piping was changed too wasnt it? Did the original owner take off the Nismo rims the higher rear wing and the bonnet or do u still have it?
Edited by krzysiu
https://www.sau.com.au/forums/topic/98858-r34-gtr-for-sale/#findComment-1813337
didnt come with nismo rims and CF bonnet. I changed the wing back to the OEM deal... it looked a bit neater..
https://www.sau.com.au/forums/topic/98858-r34-gtr-for-sale/#findComment-1813406
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
