I am selling my Liberty due to a new arrival, in the garage ( R32 GTS4 :) )
White, manual 2.2l constant awd
Hobart Tasmania - No postage...
Item Condition:
Excelent stock condition, has not missed a beat in the time I have had it, has been serviced just recently, also has 9 months rego, it does have 170k, but my flatmates 1980-something scoobie has done 400k and is still going strong. My mechanic - Terry from the automotive workshop thinks it is a great car.
Reason for Selling:
Well I was going to just have a bit of a look at the R32, mabey drive it and see if they are really that good (read time waster...) but I got back from driving it, with a huge grin on my face, made an offer and bingo, two cars, one garage!
Price and Payment Conditions:
It is insured for $14,200, so I will say $14,000 and negotiable from there
Contact Details:
Drop me an email at [email protected] with any questions
Cheers
Dave
https://www.sau.com.au/forums/topic/98863-subaru-liberty-98/
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
