High Octane Cruise -- 7th Jan 06
jdturbz
 Share
ey pplz
high octane cc have organised a huge cruise for saturday night the 7th of january @ doncaster autobarn on ther corner of doncaster and tram rds opposite westfield shoppingtown,it will be an awsome night with a huge turnout and a grouse map,this has been well organised for some time so we are expecting a very big crowd, the meet up is @ 8pm for 9 :15pm departure, hocc merchandise will be on sale including:- hocc stickers $20ea,hocc official t-shirts $25ea and hocc lifetime memberships $35 for any more info on merchandise pls call liam on 0409-516-408 he will give all the info you need,We hope to see everyone on the 7th as possible as you are all very welcome,this will be an open cruise so all makes and models and non-members are welcome to join in on the action,the camera will be rolling for the hocc dvd which wil be coming out very shortly ,anyway i wish you all a merry xmas and a happy and safe new year and we will see you all fresh and ready after the xmas break.take care and safe driving
  • 3 weeks later...
i wud hate to sign up as a lifetime member, not recieve anything then the night i pay see the person i handed the money to using the $35 to fill there car up with petrol.
I might drive past just to see the attendance but i know it will mostly be holdens and fords maybe a N/A silvia or 300zx in the mix.
Just becuase the meet point is at Autobarn, doesn't mean the staff there will have any idea what's happenining - they are not the organisers!!!
When SAU Vic has a cruise and meet at say Bunnings or a BP Service Station, we don't tell their staff we are meeting there.
Just a thought.
And just so it's clear, I have nothing to do with this cruise, was merely making a point.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
