  • 8 months later...
I had hicas but put in a S13 non hicas rack. The factory powersteering lines wont mate up so i ripped them all out and got custom ones made. Because I had a hicas pump i took the back off it an ripped out the vanes so the bitch wouldnt pump out the rear stage. I bunged it up too :)
JK
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2458922
Hella Flush so your sayying that a s14 steering rack goes straight into a cefiro with out any mods :S I find this a little different as i didnt think that s13 an s14 steering racks where the same. Not that im a silvia person unless it has 4doors and drifts it aint worth having. Cant wait for next yrs super drift rds im guna burn the candle for the cefiro crew
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2500183
as we are on the topic of power steering, i just wanted to know if the powersteering pump from the ca18det engine/s13 would work on the rb20e engine/a31, it looks the same but i just wanted to confirm this, could anyone help
thanks
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2507476
wait... on my 32 the front rack is completely seperate to the hicas rack, there is no plumbing between them.
on my friends CA silvia there is a connection that is bolted to the rack, but no fluid is mixed here.
i found this out when i locked the hicas on both cars so both definitely had hicas.
hicas cars have a pump that has 2 outlets and then the resevoir has 2 inlets, so the front rack and the hicas rack are completely seperate all the time.
i dont understand how a non hicas rack can be different then, cos i've definitely never seen any connections on the rack for hicas. rack has 2 connection, 1 in, 1 out
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2510229
are you talking about the connections near the uni joint? where the steering shaft goes in? cos this isnt actually hydraulically connected, its just bolted on there.
just checking, ive never done it on a31 but i assume its the same as s13 as the solenoid setup looks the same from the top
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2518998
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
