  • 8 months later...
I had hicas but put in a S13 non hicas rack. The factory powersteering lines wont mate up so i ripped them all out and got custom ones made. Because I had a hicas pump i took the back off it an ripped out the vanes so the bitch wouldnt pump out the rear stage. I bunged it up too :)
JK
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2458922
Hella Flush so your sayying that a s14 steering rack goes straight into a cefiro with out any mods :S I find this a little different as i didnt think that s13 an s14 steering racks where the same. Not that im a silvia person unless it has 4doors and drifts it aint worth having. Cant wait for next yrs super drift rds im guna burn the candle for the cefiro crew
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2500183
as we are on the topic of power steering, i just wanted to know if the powersteering pump from the ca18det engine/s13 would work on the rb20e engine/a31, it looks the same but i just wanted to confirm this, could anyone help
thanks
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2507476
wait... on my 32 the front rack is completely seperate to the hicas rack, there is no plumbing between them.
on my friends CA silvia there is a connection that is bolted to the rack, but no fluid is mixed here.
i found this out when i locked the hicas on both cars so both definitely had hicas.
hicas cars have a pump that has 2 outlets and then the resevoir has 2 inlets, so the front rack and the hicas rack are completely seperate all the time.
i dont understand how a non hicas rack can be different then, cos i've definitely never seen any connections on the rack for hicas. rack has 2 connection, 1 in, 1 out
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2510229
are you talking about the connections near the uni joint? where the steering shaft goes in? cos this isnt actually hydraulically connected, its just bolted on there.
just checking, ive never done it on a31 but i assume its the same as s13 as the solenoid setup looks the same from the top
https://www.sau.com.au/forums/topic/98896-power-steering/#findComment-2518998
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
