Well it’s been 6 weeks of cold the sphincter of the universe without my trusty MADGTR. Since blowing her up at Eastern Creek she has sat cold and alone in my mates workshop. I have all my parts except a pair of variable cam sprockets. Apparently they are in the country but I do not have them in my hot little hands so it makes no real difference where they are.
God I cant wait to get back behind the wheel, not that my borrowed Festiva does not have enough power to pull the skin off a bowl of custard, its just I miss the feel of a good car.
I wonder what you guys think I will dyno once I have the all the new mods in?
Performance Mods,
Old: Power FC, custom FMIC, boost to 16lb, steel wheel turbo's Nismo 80mm Exhaust cat back. High flow panel filter. KW= about 200KW @4W
New: High flowed 47.5mm compressor turbos, HKS Dump pipe, larger 6lt highflow cat, 550cc inj, variable cam sprockets, Apexi boost kit to 17lb.
NON Performance mods
Sump Baffle, head restrictor, metal Head, Inlet and Outlet gaskets, Triple core Radiator, oil cooler.
So what do you think?
https://www.sau.com.au/forums/topic/989-i-want-my-gtr-back/
yeah babs is right on it may be 250-260. I know the cold the sphincter of the universe feel I had a month with out my baby as well.
you appreciated even more. my wife was heard mumbling a couple of days later I really miss this can and I love it.
And my wife in definatly not a rev head
meggala
https://www.sau.com.au/forums/topic/989-i-want-my-gtr-back/#findComment-20932
Update.
All parts are in and the donk has the baffles, metal gaskit, head, turbo's, inj back on, and is ready to be bolted back in today. Fingers crossed I can go for a drive on Sat.
I hope the car is ready to be driven because I ready to go drivin.
https://www.sau.com.au/forums/topic/989-i-want-my-gtr-back/#findComment-25735
Big diff rwkw and 4wkw, and Im sure I could get a lot more out of the engine,but im not sure the donk would last with the hard track work around the creek. Maybe I should spend the money that Mario has and end up with 800Kw?
https://www.sau.com.au/forums/topic/989-i-want-my-gtr-back/#findComment-25764
A HKS 3037 is a mother of a turbo somewhat like a GT30 and being newer it probably flows alot better then GTR turbo's and spool faster relatively.
250 4wkw is alot of power it would be around 500hp - 550hp at the crank ! have a look at a list of super cars and tell me how many cars have around that much power.
https://www.sau.com.au/forums/topic/989-i-want-my-gtr-back/#findComment-25852
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
