  • Replies 43
It runs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11111111111111111111111111111111
You'd never guess but the engine builder didn't put my spark plugs back in and I just assumed he had.  I did notice that it was cranking fairly easily.
Put some new plugs in last night, a little bit of stuffing around and away she went.
I don't have a video recorder but I was laughing hysterically when I pulled out the first coil pack expecting to find a fouled plug but instead found no plug.
ROFL
ROFL
................................. ROFL
That's the best solution to a problem. No money spent and you can look back on the last week and trully appreciate your engine (with plugs)... LOL
Good on ya - looks like you've been a good boy this year ey.
