Hmmm.. I dont think it's a fantastic result.
I got my RB25DET done when I bought my car (57,000km's) and I got 160 across five cylinders and 150 on the other.
Yeah I heard that it's consistency that is a good thing, but the higher the better I think?
The guy who tested it (Unique Auto Sport in Castle Hill) said that they have tested heaps of RB25's and mine was up there as one of the highest they'd seen. I have heard a lot of people testing down around 140, but never as low as 125.
I'm not sure what the implications of this are though. Sorry I cant be of much help either...
https://www.sau.com.au/forums/topic/98939-compression-test/#findComment-1801813
well, i dont know what to think right now, maybe i didnt do the comp test correctly...but its even across all cylinders to the lb, so i think its all good...the engine has been very well looked after, i just did it out of curiosity...try it again tomorrow, getting a rollcage fitted so maybe they'll point me in the right direction as what it is...
https://www.sau.com.au/forums/topic/98939-compression-test/#findComment-1802063
125 isn't perfect but still in the reasonable limits. It's good when all the cylinder have lost compression equally, but losing compression doesn't mean a real lot as it's turbo, the turbo's will always have less psi than a N/A engine. I don't own an RB25 though but this compression is good enough (not great) for a turbo engine
Cheers
https://www.sau.com.au/forums/topic/98939-compression-test/#findComment-1802667
theres no smoke or oil used, the turbo seals are blown out but driving off boost it doesnt smoke at all, power is still fantastic...i have a feeling the low readings were because my battery is ratshit...like i mean..if you start it and stall the car, be prepared to push it..that and my throttle body was closed...
Looking at my spark plugs, theyre almost brand new still, no buildup of anything at all, engine overall seems to be running brilliantly. Must have been the way i did it...
BTW, sorry nismoid...i searched but i didnt get a straight answer to what i was looking for so i posted a new thread...my bad...
https://www.sau.com.au/forums/topic/98939-compression-test/#findComment-1803007
I wouldn't have thought this is much for an rb25, but I have heard that an even spread across all the cylinders is more important.
My rb25det from a 97' s2 r33 has between 153-160 across all cylinders, being the lowest and highest from all readings.
125 sounds a little low, but if the others say its ok if it aint using oil and water etc, then i could be wrong. Possible try testing another one if you can, just for reference.
https://www.sau.com.au/forums/topic/98939-compression-test/#findComment-1816005
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
