How It Dies?
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Just if anyone knows where to disconnect/cut the wire/destroy this little "dinging bastard", could you point me in the right direction. My sanity will be most appriciative...
Have used search, typing "speed chime" and everything relating to the word "speed" comes up, so, didn't really get far...
Thanks.
Edited by QUIKBLADE
https://www.sau.com.au/forums/topic/98940-105-kmh-speed-chime/
Just new on here... but what i did (kinda hard to explain) was if you take the gauge cluster out:
The yellow circle and the green arrow are to help you get your bearings:
Green arrow = up
Yellow circle = the bulbs for PRND21
Not in the PINK circle is the ribbon type bit you wanna take out or put a slit in. It has 4 "wires" (dont know exactly what to call the ribbon type wire setup lol) one says 100k, 2 grounds im guessing and one says 10k.
So if you chop this it should work... ive done this to mine but the only catch is that i cant test if it works properly yet, as my speedo doesnt work cos the speedo drive in my manual box is an electronic sendout, as supposed to cable. I see this working, but conformation on this would be appreciated!!!
Sorry i cant be more help, but hope this does help in some way!
Edited by _Jake
this has been covered a few times ...there is a small black box under the dash down neer ur left knee below the steering wheel. there are two boxes ....so just disconnet one cant remeber which but just pull the plug out.
you should beable to find it by searching
Somestole CC (aka Tom) & I happened to do this removal whoha and take some happy snaps......simply under dash (about where the red arrow is) look for a little box like the one in the pick and unplug the bas&*rd of a thing!!
Excuse the fugly mug shot! <_<
Cheers,
Ando
Cheers,
Ando
thanks... the morning can't come quick enough for me to detach that damn thing.... Guess my next question would be: WTF is the point of a chime at 105?!! :blink:
i found a cure for mine... just get an extremely loud exhaust... :blink:
My exaust (86db at idle) my diff, louder than that, my stereo, and my window down can NOT get rid of that sound. I doubt death its self could get rid of that sound. Even when we got rid of the thing I could still here it for a week after everytime I hit 105kmh.
But yeah, its the left knee thing. Make sure its the right one (the other will effect your alarm, door lights, left head lights on sound etc). When you have it, KILL THAT BARSTARD THING!!! THROW IT, JUMP ON IT, SHOOT IT!!! Yell BEEP BEEEEEP at it.
You WILL feel better.
No worries dude!
CC- Mate half my fault as well. Was supposed to burn all the piccies onto a CD for ya....OOPPS
P.S. Voted for smash the little fcuker to pieces.....there is just something so liberating about taking hammer in hand and destroying an object to obliteration!!!!! :D
Ando
HEHE,
I chose burn in hell :)
Funny, i didnt even know Ceff's had that stupid chime noise at 105km/hr, mine must have been removed by a previous owner in Japan.
Still dam annoying, my G/F's toyota soarer starts chimeing at 105km/hr, pisses me off something chronic
My post up the top? about taking the gauge cluster out? Is it not showing?
yeh but that is way hard. Pull out the cluster and then play with the circuits...
or you could just cut out the chimer, i know which one I would choose.
all in all your idea is more thorough but sucks the african jungle poll B)
I say Smash it to pieces and then burn it!
I'm pulling that sucker out tomorrow morning. I'm driving for 4 hrs from Melbourne to Mt Beauty on Monday and the speed limit is 110 most of the way!
Thanks for the tips!
Hey guys does your just go off at 105 k's???
As mine also goes off at 60, 80, 125, 160, and then goes nuts at 180..
Just wondering if anyone else's does this??????
LoL dude, yours just sucks! Get rid of it!
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
