considering there was a thread about this last week...
for 300rwkw, you may aswell get used to the idea you'll be shifting manually.
For one the stock box wont take anywhere near that kinda punishment.
A Jatco with around 1k-1.5k spent on it is what you'll be after.
And then its going to be full manual shiftment
I have allready had a shift kit installed, and working on a high stall to get rid of some of the turbo lag. At the end of the day i brought the car for my wife to drive to the shops, as she loves the grunt that the skyline puts out , yet she would rather concentrate on the road then flat changing second when some tosser in a commodore gives her a smile at the lights.. hence i got the auto...
Whats this Jatco box your on about? do you know where i can get one from if my box bites it. also any ideas on suitability of different high stalls, and revs?
The turb dosent start cooking til near on 5000, but a 5000 stall would be a little impractical for shopping.. any suggestions... Cheers
turbo at 5000rpm? what on earth have you got fitted to it?
the stock turbocharger comes on at 2800rpm.
if oyu do the basic stage 1 mods it sohuld be a quick street car whilst retaining the stock ecu still.
cold air intake
boost controller
remapped or apexi safc
3" turbo back exhaust with split dump
front mount intercooler
should get you near 180rwkw and be plently quick enough with a good shift kit and maybe reco'd auto box and bigger transcooler if your worried about reliability. the jatco box is from the vl turbo rb30et and its a very tough box if reco'd and setup properly, have a look on calais turbo for some jatco workshops who can quote / give you some advice. if you wanna stay under 200rwkw then the stock box is probably fine. just service it and get a bigger transcooler.
There was a car in last months issue of HPI if I remember correctly that used bikkirom, can't quite remember all the details though. Will have to look it up again, I think they were using it in a Ceffy?
"My cat's name is Mittens."
cold air intake
boost controller
i have already done most of the bolt on mods, including gt30, pump, reg, fmic, cold air, electric boost controler, stainless low mount manifold,3inch dump straight thru to rear tip. and soon to order injectors and ecu...
I fitted the first ever Wolf plugin (was the proto type) to an R33 GTS auto around 2001 and this car still has had no trans problem.
The car is around 300rwhp and was a daily driver city car but for the last 2 years has been in the bush driving from margaret river to busselton evrey working day.
For the WA ppl this was Grant from PER4MANZ Turbos car and now belongs to Jamie wholagan and many would know he spares no car.
Nissan autos are Jatco but the toughest Jatco to start building with is the VL commodore turbo box and it needs no input from the ECU.
yeah, wasnt totally clear :D
the VL isnt the elec box like the R33/R32/R31 (series3) boxes are.
the elec boxes are total crud to rebuild
as for 300rwkw from an auto/GT30.
I dont think thats realistic. 280rwkw at the most.
The auto sucks a bit more of the power as opposed to the manual
but 5000rpm - no way a gt30 in any spec would be that late. even with a 1.06 housing
i was in the same position for finding a ECU for my auto r33
i was gettin mixed opinions of if it worked or didn't
as to saying that it "worked" meaning the car moved
apperantly gear changes are bit harsh and gearbox wont last too long
and chasing 300rwkw gearbox won't last that long either.
I changed the gearbox to manual, drive in drive out for 2500
didn't really want to do that, but hey, i knew gettin a aftermarket ECU was definately going to work.
and didn't have to muck around with rebuilding box, getting a shift kit, a stall converter, or finding a ecu that might work or not.
I'm modding my car close to 250rwkw, and know the manual will be right, might have to get a new clutch, but thats about it.
Also with the advantage of knowing what gear you are in, being able to power through corners, without the concern of changing down a gear on ya. ( Nearly lost it once going around a corner and changed a gear on me , ass end got a bit happy, bit exciting)
Also i want to get into the drifiting side of things, the auto would of been a bit weird.
But yeah if ya want a spare autobox, i have one.
THanks
Barret
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
