only because its been covered 100's of times before and the search button is your friend.
If you wanna get back onto specifically ECU, and not the AUTO part of the 300rwkw, then this thread has done its use-by :P
he r31nismoid i have looked thru many a thread, yet still havent got very far.. what would you recomend for me to get as a ecu? or can you point me to a thread that might help... cheers...
Have a chat with the guys at MV Automatics in Blackwood (Adelaide SA) they have done a lot of this stuff. You can get Valve Bodies, Torque converters, Carbon Fiber Clutch packs (I believe) etc from them. I have also heard that some of the Nissan Patrol parts are interchangable for high torque applications.
Remember its not the KW that will kill a transmission its the Torque and heat.
Once again the ECU and Auto gearbox ECU questions get totally off the plot.
Search all you like, there is no full ECU replacement for auto Skylines. The current situation, as I see it, is you have 4 choices;
1. Suffer harsh gearchanges and reduced gearbox life and use any ECU you like. They are all the same as far as the gearbox is concerned. None of them have the gearshift logic programming for cutting/retarding the ignition timing on gearchanges. Saying that Microtech or Link or Power FC or anyother ECU is better for autos is absolute crap, NONE of them have the programming.
2. Use piggy backs, SAFC, SITC, EManage (there is a claim that EManage now works with Skyline ignition, but it is early days yet) or Exede (still under development). They all retain the standard ECU and therefore its program for gearshift logic ignition retard. What's the limit as far as amx power is concerned? I don't know, I haven't seen anyone reach 300 rwkw with piggy backs yet, there are a few around 250 rwkw though.
3. Change the gearbox to manual and use whatever ECU you like.
4. Change to a stronger auto, you will still have harsh changes and the life of the gearbox will be less (than it would with ECU programing for gearshift). Or upgrade the components in the standard gearbox, so they last a bit longer. Or use a manual shift controller, so you decide when the gearchanges are going to occur (you can take your foot off the throttle on the gearchange).
This is not going to change as far as I can see (so don't search again tomorrow for a magic solution) because no one is going to spend the money developing the programming for an aftermarket ECU for Nissan autos. It would simply cost far too much and be unsaleable (no one would pay the price). This has been the case since 1989 so why would it change now?
:D cheers :P
PS; Yes, there are Power FC's for auto Toyotas but they have comletely different logic in their gearshift and ECU. This means no complex programming is required (like a Nissan).
Edited by Sydneykid
just a question...
I have been led to believe that when setting up any aftermarket ecu eg wolf, power fc, etc they will give you grief with gear changes..
But has any one tried leaving the standard computer in control of the auto and other car functions and wiring in the aftermarket ecu to control timing, fuel and boost etc.. basically running the engine from the wolf and the trans and car from the standard ecu.. i believe this can be done just by getting another ecu loom plug from the wreckers and cutting out the wires not needed... any thoughts?
doesnt work , read above .
"1. Suffer harsh gearchanges and reduced gearbox life and use any ECU you like. They are all the same as far as the gearbox is concerned. None of them have the gearshift logic programming for cutting/retarding the ignition timing on gearchanges. "
SK has completely summerised they options avaliable and there are no more .
hence read what i said...
The two ecus would have to be able to communicate in some way - like the stock one would have to be able to cut the timing etc when shifting... don't see how that would work tho... would be really complicated if at all possible..
Yes, a heap of people have tryed wiring over the top of the original harness. The problem is that in order for a proper change the ignition must be cut back a certain degree as a sort of torque reduction operation. Now if you could use the output of any one of the torque solenoids as input into a computer that was able to retard timing a certain amont then it would be able to be done. How well it would work is unknown and I only now of one computer that could do it.
there is no shift logic in the ecu you want to control the engine.
also you will have problems sharing sensors , for example the TPS signal which both ecus will require just to operate properly let along change gears properly
Thats what I was thinking - The ECU's would have to know when to let each one take over to control the shifting(Timing etc)... I don't think it would possible(Well not cheaply or simply) It would be too complicated...
You shouldn't share any sensors when wiring an aftermarket computer over the top of the original ecu as the internal biasing will most likely be different. Whenever we wiring in like this we always install new CLT and IAT and sometimes TPS sensors.
cheers for your imput guys... it was actually the sales rep from wolf that suggested wiring the two computers together.. he may have ment leaving the standard computer in control of timing so therfore it can control the auto, and use the wolf for everything else.. not sure.. but he was fairly sure it would and does work well...
. it was actually the sales rep from wolf that suggested wiring the two computers together.. ..
thats no surpise , there was a very prominant wolf dealer on here who insisted that it would work also until you finally pinned him down on the facts and then it was admitted it acted exactly like every other ecu
so dont worry many of us went through the same process of investigation and finally acceptance of our fate when we got a 33 auto
then i just got a manual conversion and powerfc and never worried about it ever again
just a question...
You could use any ECU to control the fuel and use the standard ECU to control the ignition (for cut/retard on gearchanges). The control of ignition timing must at all times remain with the ECU that has the shift logic programming (ie; the standard ECU). That solution would be hardly any better than a piggy back solution like an SAFC or a DFA. It would certainly be inferior to SAFC + SITC or EManage (if it is finally bug free) or Exede (when the development is finished).
:D cheers :P
PS, quick clarification, the (engine) ECU has absolutely nothing to do with the actual changing of gears. That is handled by the (transmission) ECU.
Edited by Sydneykid
thanks for being truthful... I hate when sale guys bullshit to you just to get a sale.
so then i change my question... emanage, emanage ultimate, or rebuilt vlturbo trans with a high stall and install power fc...
obviously the last option is big dollars but the best result...
amy thoughts :P
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
