well... this mite be a stupid question. but il ask anywayz
last nite i was dragging mmy mates wrx
out back of werribee we got a few 1/4 miles marked out
me being stock and all and his wrx having full 3 inch exhuast from turbo and boosted up..
off course i thought he was gonna kick my arse but i never back down from a drag race..
so anyways on take of he kicked my arse im talking 2-3 car lenthgs
i was wheel spining way to much where he just took of.. damn AWD
but still as we went on i started catchin him.. at the end of the 1/4 mile i was practically dead even with him..
but the question is......
WHATS DA BEST WAY OF GETTING TRACTION?? is it the plane and simple answer of geting some 255 wheels at da back.. or is there any other tricks of da trade>????
i tried taking of in 2nd gear like what we do in my mates VL but the skylines seem to buckle down and dont like it much..
hmm
any help would be great
thanks
ps..
Inark is gay..
https://www.sau.com.au/forums/topic/9897-traction/
Traction is not about RWKW, in fact the more kw the more harder to get the traction issue right. IF in 1st gear, doen't rev it past 4k max, it all about ballancing the power delivery. Maybe try to use your hand brake to launch, this way your engine is loaded (thus starting to spool the turbo, and yes you may be riding the clutch a little. This is just my opinion i would also like to read others.
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153639
If you've got the $$$ get some good tyres on the back, it'll make a big difference.
I'm not talking 255 rubber, just a really good tyre. I got a set of 901's on the back and they are so much better than what I had.
Pineapples are apparently a good thing too (they are on my 'to do' list). Reduces axel tramp and gives better grip.
Funny that your GTS-t is stock, and after the 1/4 mile it's even with a silghtly modded WRX - I love it :D
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153675
You gotta learn not floor it during take off and hold the enthusiasm a bit at bay. Flooring it off the line isn't the best in a RWD. Wait until you're moving a bit then fully give it the boot.
Handbrake starts for me just result in more wheelspin...
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153731
Deffinetly get some "PINEAPPLES". These things will cost you $120 delivered from Meggala and Dr_Drift yet they are worth soooo much more.
Considerably removed my axle tramp and my car is 500% better off the lights and around short fast corners the rear end sticks.
You can read my small review
HERE
https://www.sau.com.au/forums/topic/9897-traction/#findComment-153749
I _should_ be getting my car back tonight with the pineapples. I'll post how it goes post-pineapple. Soon everybody will have 'em :)Mine generally bounces around like a m/****er and goes nowhere on high boost if i don't do it properly.
https://www.sau.com.au/forums/topic/9897-traction/#findComment-154133
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
