hey guys,
i was wondering your thoughts on how well a greddy td06-20g with the 8cm ehxuast housing would go on a rb20. Currently i have tomei cams, gtr injectors, bosch 040, power fc, hks front mount, 3.5 inch exhuast. Just wondering would this put out a fair amount a power on an rb20, and will this be laggy with the 8cm housing? i need full boost by around 4000rpm...
https://www.sau.com.au/forums/topic/98986-rb20-greddy-td06-20g-8cm/
  • Replies 68
Posted Images
he later changed to the 8cm housing and managed to pick up power both lower and higher in the rev range.
i believe his car was making ~240rwkw on 18psi, but i think he sholuld confirm it.
btw, for the people in the know, what are the exact differences b/w the td06-20g and the td06-25g?
yes come to think of it i've heard it's no good on two doors. will probably only work on blitzs four door. i'm sure he'll do you a favour and pay for the freight to his house to get it out of your way.
YUP...8cm and dyno'd at 234rwkws @ 17-18psi. It really startes kickign at 4,5400rpm, but the wastegate is creeping open just as you get to around 4,000-4,150rpm. The wastegate does creep open a little as im not using an EBC so its possible (??????) i could get it to come on a little harder. But traction is just about perfect so ramping it harder onto boost may make the car slower...i dont really know until i get the car back and some more money for a new AVC-R.
The TD06-25G not only uses a bigger compressor but also a much bigger turbine. Completely different turbo that seems to make 50-60more rwkws then a TD06-20G
Well in my eyes the car use to be pretty tidy for an old R32…but then I had a small underbonnet fire at Winton 12 months ago which needed a new harness and blistered the paint on the bonnet. (And killed the AVC-R)
Didn’t take much to get the thing going again, and so it did after a tops re-tune, I drove the wheels off the thing for the next 5-6 months. In which time I had a big 270deg lose @ 150km/h at Calder where I just kissed the tyres, putting a slight dimple in the guard that already had paint damage from the fire retardant used on the fire….then I binned the car in the wet at Eastern Creek, into the tyres at Turn 8 :D Car was still driveable but it was starting to look , no…did look like a piece of sh1t
So a respray and hopefully a bit a reduced tendency to bin my car at the track in 2006 will mean I get more enjoyment then ever out of the old girl…long winded but you did ask :D
And my turbo runs an external gate…will be interesting to see your results with the T3 flanged turbo, as I suspect they don’t work near as well as the normal 3 bolt external type TD06, especially as they have to make do without the nice Greddy exhaust manifold :D
i have a hks wastegate actuator to run on it so hopfully it controls some big boost well, im lookin for around 230rwkw so i hope to get it, ill post up my results when i get it retuned with the new turbo. oh if anyone is interested in buying a high flowed stock turbo in the next month that is in pristine condition dont hesitate to give me a buzz as i wont need it anymore.
This would be better suited to a RB25 then I guess?!
so how much would you be asking for the turbo and is it an RB20 hi-flow or RB25? basically does it meet up with a stock dump from a R32 gtst? Thanks mate
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
