  • Replies 68
Posted Images
Can I just make a point here, firslty, if you want a laggy turbo on an rb20 then you got to enter your corner pretty hard cause you wont be able to spin it up fast enough on a slow entry, unless you pop the clutch. So I recon the bigger the turbo the harder the entry and also you dont have the car on full throttle all the way through the drift, so you only really running about 60-80% on the throttle. I recon your better suited to something a little smaller rather than bigger on the rb20.
waldo, all due respect but i think you are going about this the wrong way. for a nice quick driftable car something like an HKS 2530 will be perfect for you. 180 to 200 rwkw is plenty for fun in a GTST and will give you great throttle response (well better than the trust kit). Don't get me wrong, the trust kit is great but i don't think it's well suited to your purpose.
2530 is great on an rb20.
around easter creek i can hold 3rd thru some of the corners where u can use 2nd instead and it picks up really well, its getting 0.5bar @ 3000rpm and 1 bar at ~3600rpm which i think is don and 1.25bar @ ~4000rpm
roys setup is making a much nicer top end
What lap time are you running around Eastern Creek and on what rubber??? (This is Roy, co9uldnt be bothered logging out and in :) ) I did notice at Eastern with the TD06 i did struggle on Turn 7 :)
Hey Roy, is this the same one you are using, its from nengun for about 2 grand. Also do you no what the specs are? Do you think the turbo is at its limit on your car or do you think it still has some left, thanks.
Just curious what it would compare to in the garret gt range.
Type TD-06S , Compression Housing 20G, Exhaust Housing 8.0cm2
Edited by grim32
try asking James on NS about trying to drift his 4 door 32 wt td06 25g (he bought the kit of the guy in the hpi write up) from what he has said to me its lag city
It all depends on the track your going to be drifiting my 2530 makes my life hard going around Port G as its such a small track.
On a track like Mallala I'd probably be very happy with the 2530
just remember to do lots of limiter clutch dumps works for me
well i drift at queensland raceway and it has to be one of the fastest tracks in aussie... it doesnt have tight corners anywhere really they are really long high speed turns. So it should probably suit this track as it would be better to have a really nice top end power band than low down.
heres some more pics of mine...im not sure wat the trims are on these but its a 20g housing.
TD=mhi turbo
06=turbine WHEEL
20g=comp WHEEL
L=SUPER BACK comp wheel
s=flat back comp wheel
h=large turbine
exhaust housing you already know the sizing
comp housing is the big long part no. on the front of it
cheeres :O
td06=mad turbo; so very underated :D
Edited by T04GTR
cheers for that info mate.....does anybody know wat size the oil fiting is for the oil feed for these jigas..also because the stock turbo has oil + water lines and i only need oil ones...wat do i do with the existing water lines..do i just bung the holes in the block or do i get a hose made up to link both holes? i just want to get all the oil and water lines done soon.
cheers
Waldo, looking at the rear housing on that turbo, i wouldnt even bother putting it on the car...any money spent plumbing that bad boy up would be dead money. Run Straight out and buy an external gate exhaust housing for it...looking at that rear housing m not surprised that the T3 flanged TD06s dont make the power they should.
Of course i could be very, very , very wrong, but i flat out dont like howthe turbine and wastegate is set up, turbulence / back pressure city which means cant run as much ignition, combustion chambers full of already combusted air, and poor flow....
1400r, as others have siad in this post, the 20G and 25G are two very different turbos
And grim32; Type TD-06S , Compression Housing 20G, Exhaust Housing 8.0cm2... Sounds similar, but i think mine is the TD06L2-20G, cant be sure though as it came off a twin GTR kit
i was sorta thinking that with this type of exhuast housing it shouldnt effect the spool up much...as ill be running an electronic boost controller...and the wastegate will stay completely shut until its on full boost anyways...which it shouldnt affect spool up time but might cause it to struggle a bit when on full boost. i was under the impression that the wastegate stays completely shut until u hit full boost (with the use of an ebc). am i right or completely wrong lol.
I look at where you bolt your dump pipe to, and i see a large cavity, full of square edges. The when the thing finally hits the boost you want to run, the little wastegate flap opens and the air runs straight into a wall, then has to blend with the exhaust gases coming off the turbine which are already free to bounce around in the cavity before the dump pipe.
I hope Trust/Greddy no more then me, and it may work just fine. Are you sure thats a genuine Trust/Greddy housing on the turbo?
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
