i recently purchased some decals for my car (the same as the ones in the attached image) and they have just arrived, seeing they cost close to $200 inc shipping the last thing i want to do is bugger them up, basically just asking if anyone has applied these kind of size decals to their car before or knows of anyone/company in adelaide who could help me with it, they did come with instructions but am not too sure about attempting it myself (worried about leaving air bubbles etc) thanks guys!
https://www.sau.com.au/forums/topic/99035-applying-decals/
I've done this before, you just have to do it really slowly. Make sure you paint is perfectly clean and dry, take off the backing sheet, lay a small corner piece on and then apply using something with a nice flat surface, like a credit card etc. Make sure you push the air out as you go, and the end there may be a couple of tiny air holes, get a pin and gently pop them, then slowly peel the top sheet off, again using the cridt card or what ever as you go, and presto it's on. Also a good move to rub over the decal with the card prior to fitment so it's stick properly to the top layer of paper, otherwise parts can end up staying on the bottom piece and totally f**king it up.
Best of luck mate
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803619
sounds quite expensive for 400R/nismo style decals. but like mxtcy has suggested, take it real slow. patience is the key, in my opinion there is no need to take it to someone else to do it as its just going to cost you more money - i assume so anyways.
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803735
spray windex on your car, put the decal on, move it into place and wipe down with your credit card to make sure it's all smoooooooooth, let it dry then peel top sheet off........IS DONE IS GOOD!
BINGO!! DONT do it dry 1 stuff up and its there for good kiss 200$$ goodbuy
i used to work @ olympic trailers and they used a simular method i think with just water spray to put there stickers on... u can get bubbles out with a rubber squigee
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804536
cheers for the advice, gonna give it a go tonight with a mate, ill let you know how it goes :)
where did you get them from thirty four?
got them off ebay from a guy based in hong kong
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804667
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
