i recently purchased some decals for my car (the same as the ones in the attached image) and they have just arrived, seeing they cost close to $200 inc shipping the last thing i want to do is bugger them up, basically just asking if anyone has applied these kind of size decals to their car before or knows of anyone/company in adelaide who could help me with it, they did come with instructions but am not too sure about attempting it myself (worried about leaving air bubbles etc) thanks guys!
https://www.sau.com.au/forums/topic/99035-applying-decals/
I've done this before, you just have to do it really slowly. Make sure you paint is perfectly clean and dry, take off the backing sheet, lay a small corner piece on and then apply using something with a nice flat surface, like a credit card etc. Make sure you push the air out as you go, and the end there may be a couple of tiny air holes, get a pin and gently pop them, then slowly peel the top sheet off, again using the cridt card or what ever as you go, and presto it's on. Also a good move to rub over the decal with the card prior to fitment so it's stick properly to the top layer of paper, otherwise parts can end up staying on the bottom piece and totally f**king it up.
Best of luck mate
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803619
sounds quite expensive for 400R/nismo style decals. but like mxtcy has suggested, take it real slow. patience is the key, in my opinion there is no need to take it to someone else to do it as its just going to cost you more money - i assume so anyways.
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803735
spray windex on your car, put the decal on, move it into place and wipe down with your credit card to make sure it's all smoooooooooth, let it dry then peel top sheet off........IS DONE IS GOOD!
BINGO!! DONT do it dry 1 stuff up and its there for good kiss 200$$ goodbuy
i used to work @ olympic trailers and they used a simular method i think with just water spray to put there stickers on... u can get bubbles out with a rubber squigee
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804536
cheers for the advice, gonna give it a go tonight with a mate, ill let you know how it goes :)
where did you get them from thirty four?
got them off ebay from a guy based in hong kong
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804667
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
