Hey all,
I test drove a 92' R32 GTS4 the other day, it has 143,000km and mods include: lowered on king springs, hybrid front mount installed, organic h/d clutch, running 13-14psi via one of those t-shape boost controllers, full 3.5" turbo back apexi system, apexi pod filter. It has had its major service apparently.
The problems the car has at the moment are;
1) Syncro's for 3rd, 4th and sometimes 5th are farked, it crunches hard into 3rd and 4th if you don't change into them ever so slowly (then it doesn't crunch if you REALLY baby it into gear).
and 2) The rear diff makes a whiny noise at about 80km/h-90km/h, then when you get up to 100km/h it appears to go away. Isn't overly loud, but is noticable.
3) The rear door locks dont function properly, the right rear door you cant open from inside or outside, and the left rear door you can only open from inside.
4) Front left brakes make a bit of noise sometimes (they've just been machined, the guy reckons all it needs is a $5 brake pad clamp to fix)
Aside from that, the car drives very nicely and is quick. The interior is awesome and is the updated stuff, MUCH nicer than the 1989's, the paint work is also awesome.
Are these problems indicative of any kind of serious misstreatment of a GTS4? I mean, it's probably been given a bit in its time like all Skylines, but if the compression is good on the motor is it still worthy of a buy? The seller says his mate who runs a performance workshop can supply a new GTS4 box and install for ~$550, and can supply a new rear diff for $125. I'm dubious about how much it will cost to fix the 2 rear doorlocks though. I can pickup the car for ~10,000.
Constructive opinions please :)
Edited by esprit
Come on guys need some knowledgable opinions here!
The car is 15 years old, has done close on 100,000 miles. So it will probably be tired - it certainly sounds it. For my ten cents it is probably better finding something that you don't have to spend 2 or 3 thousand on to get it up to scratch. There should be loads of R32 on the market presently.
By my calculations:
1) New gearbox supplied and fitted - $550
2) New rear diff - $125 (self fitment)
3) Rear door locks - $100-$150
So its not going to cost me another $3k at all really.
It was compression tested today:
145, 145, 145, 145, 140, 139
A lot of the R32's on the market have sub 100,000km odo readings, which I really find hard to believe. It's obvious they have been wound back and have probably done 200,000+ (especially the 1989-1990 models).
There is a lot on the market, but most are 1989 models (which are horrible inside), and people are asking too much for them as well.
Symptom 1 is a sign of a bad manual driver :D
the rest are just signs of age. Most of which are easily fixable. Any mechanic/auto elec should be able to sort out the door.
10k is not a bad price for a GTS4 that came in under the old CPA scheme, and isn't on the verge of a coronary like some of the 15 yr old ones that people pick up cheap to make money on.
What's the rest of the car like, interior, panels etc? rust? bends, dints, dents, scratches?
ok i got my 89 4door gts-t, wit 61 thou on it, its not wound back because u can tell if u throw it on the hoist, it has little dirt on the under body, i know it may be rare but its still achevable so dont rule out a 89, btw it snot much diff to the new 32's on the interior, so im guessing its a 4 door?
So little dirt under it? they probably washed it for that particular reason. to make people believe the ks.
When I first got my car, it looked spotless under it like it was a brand new car. 5000ks later, it now looks as dirty underneath it as my dad's car with 100000ks on it.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
