Hey all,
I test drove a 92' R32 GTS4 the other day, it has 143,000km and mods include: lowered on king springs, hybrid front mount installed, organic h/d clutch, running 13-14psi via one of those t-shape boost controllers, full 3.5" turbo back apexi system, apexi pod filter. It has had its major service apparently.
The problems the car has at the moment are;
1) Syncro's for 3rd, 4th and sometimes 5th are farked, it crunches hard into 3rd and 4th if you don't change into them ever so slowly (then it doesn't crunch if you REALLY baby it into gear).
and 2) The rear diff makes a whiny noise at about 80km/h-90km/h, then when you get up to 100km/h it appears to go away. Isn't overly loud, but is noticable.
3) The rear door locks dont function properly, the right rear door you cant open from inside or outside, and the left rear door you can only open from inside.
4) Front left brakes make a bit of noise sometimes (they've just been machined, the guy reckons all it needs is a $5 brake pad clamp to fix)
Aside from that, the car drives very nicely and is quick. The interior is awesome and is the updated stuff, MUCH nicer than the 1989's, the paint work is also awesome.
Are these problems indicative of any kind of serious misstreatment of a GTS4? I mean, it's probably been given a bit in its time like all Skylines, but if the compression is good on the motor is it still worthy of a buy? The seller says his mate who runs a performance workshop can supply a new GTS4 box and install for ~$550, and can supply a new rear diff for $125. I'm dubious about how much it will cost to fix the 2 rear doorlocks though. I can pickup the car for ~10,000.
Constructive opinions please :)
Edited by esprit
Come on guys need some knowledgable opinions here!
The car is 15 years old, has done close on 100,000 miles. So it will probably be tired - it certainly sounds it. For my ten cents it is probably better finding something that you don't have to spend 2 or 3 thousand on to get it up to scratch. There should be loads of R32 on the market presently.
By my calculations:
1) New gearbox supplied and fitted - $550
2) New rear diff - $125 (self fitment)
3) Rear door locks - $100-$150
So its not going to cost me another $3k at all really.
It was compression tested today:
145, 145, 145, 145, 140, 139
A lot of the R32's on the market have sub 100,000km odo readings, which I really find hard to believe. It's obvious they have been wound back and have probably done 200,000+ (especially the 1989-1990 models).
There is a lot on the market, but most are 1989 models (which are horrible inside), and people are asking too much for them as well.
Symptom 1 is a sign of a bad manual driver :D
the rest are just signs of age. Most of which are easily fixable. Any mechanic/auto elec should be able to sort out the door.
10k is not a bad price for a GTS4 that came in under the old CPA scheme, and isn't on the verge of a coronary like some of the 15 yr old ones that people pick up cheap to make money on.
What's the rest of the car like, interior, panels etc? rust? bends, dints, dents, scratches?
ok i got my 89 4door gts-t, wit 61 thou on it, its not wound back because u can tell if u throw it on the hoist, it has little dirt on the under body, i know it may be rare but its still achevable so dont rule out a 89, btw it snot much diff to the new 32's on the interior, so im guessing its a 4 door?
So little dirt under it? they probably washed it for that particular reason. to make people believe the ks.
When I first got my car, it looked spotless under it like it was a brand new car. 5000ks later, it now looks as dirty underneath it as my dad's car with 100000ks on it.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
