as the topic says my headlights keep blowing. i make sure not to touch any part of the globe when putting them in and the last a few months then blow first the drivers side then the other side a few days later.
has anyone had this problem or have any ideas on how to fix it
thanks, Mark
https://www.sau.com.au/forums/topic/99048-blown-headlights/
"Is your car lowered or using coilovers???" This was the first question a guy at autobarn asked me when i had this problem in my silvia. I was blowing globes on a regular basis too and had stiff coilovers. Apparently they shatter the filaments very easily when ur car is lowered or has hard suspension. Replaced the coilovers with normal sports suspension and problem has disappeared!
https://www.sau.com.au/forums/topic/99048-blown-headlights/#findComment-1804817
not lowered n stock suspension as far as i know.
they were good globes i think artic blue by phillips i think.
wat amp should the fuses be.
thanks for all the help guys, i'm driving round on high beams at night coz tehre is no point changing them if they will jsut blow
https://www.sau.com.au/forums/topic/99048-blown-headlights/#findComment-1806161
arctic blue is the problem. those are rice globes. have you noticed that the non white phillips globes are road legal. but the guy where you bought it from shoulda told you that they're not road legal, coz of the short lifespan.
it's pretty obvious you won't be defected for it, as a cop won't know shit. but the down side is they don't last long. Mine used to blow abobut once a month.
the reason is, the blue coating makes the light bluer, but therefore, not as bright. to make up for it, they overpower the filament. which shortens it's life
https://www.sau.com.au/forums/topic/99048-blown-headlights/#findComment-1807626
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
