I just prchased a R32 GTS-T completely stock but have put a air intake and a boost controller to 14psi. However the boost controller is installed correctly and the boost reads 14psi when driving but didn't increase the speed or top end much at all.
I've been told the standard turbo is no good for this and a R33 GTS-T is the way to go with a FMIC? I would like to hear any other suggestions for this. PLEASE HELP
I thought R32's had alot more than this but apparently they all are like this.
https://www.sau.com.au/forums/topic/99072-r32-gts-t-need-more-power-help/
Maybe for tune is out of whack? Fitting an R33 turbo will be good as the R32 turbos will come apart around the psi you are using. Fitting a front mount will increase the power but i'd be thinking that maybe your car needs a good tune.
Run some injector cleaner through it as the injectors may be abit dirty and will clog up.
Test the compression? Maybe your engine is lacking compression and therefore power
For a start you will need to get the car tuned.. so it will require some device to let you tune it.. just winding the boost up to 14psi and expecting instant power increase is not going to really work.
in my experience, fitting an rb25 turbo will give you bit more mid and top range.. on the street it may actually feel slower, and a bit more laggy at coming on boost.
14psi on a standard R32 i properly wouldn't run the boost that high turbo won't like that much. All depends on what sort of power you are hoping to get out of your car and how deep your pockets are really. I have just finshed building my up i got 210rwkw which i am quiet happy with but it cost a bit as i had to rebuilt my engine as it was shagged. And then it is a matter of bolting all the go fast bits on getting yourself a after market ECU and a good tuner (Don't take short cuts with the tuning most important thing) If you want to know my mods sent as a PM if not good luck with the hunt for power
stock boost is 10psi already so uve only added 4psi but still not worth it on that turbo cause it wont be much better and could cook the ceramic turbine
i always found with the stock turbo it would hit you in the back at about 2500rpm and pull almost the same to the redline - fun for punching at low rpm but no hang on at high rpm :)
should be sweet to run 14psi with a rb25det turbo on the 2ltr and u get some pickup from 3500 onwards :(
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
