Article: Saleen day for Bugatti!
Saleen S7
Twin turbo V8
1000hp
1360kgs
6 Speed Manual RWD
416km/h during testing
0-100 in 2.8secs
Bugatti Veyron
Quad turbo W16
1000hp
1600kgs
7 speed DSG AWD
407km/h in production spec
0-100km/h in 2.5secs
What do people think? If it were free, I'd still take the Veyron.
https://www.sau.com.au/forums/topic/99077-bugatti-veyron-dethroned-already/
  • Replies 40
To draw comparison between the 2 cars ould be like comparing a plasma TV gainst a rear projection TV, both are big and delivers visual image but you know which one is refine and definatively better.
I wouldnt say the Veyron has been knocked off entirely, considering it has a speed limiter in place & what Saleen is offering is an aftermarket upgrade. I'd hope the tyres + wheels on the Saleen will be able to handle those speeds or has a similar safety feature like the Veyron to keep them inflated when they shi7 themselves.
Anyone seen to see if they CRASHED BUGATTI YET?
I checked Wrecked Exotics and they only had images of the previous V12 model, so I don't think there are any wrecked customer Bugatti Veyrons yet.
pics mate, pics
This is the pic from the link:
Another pic. 1000hp!
Im not sure I would want to be reversing that thing, givent that the engine seems to block any view behind!
Edited by Big Rizza
i think the Bugatti Veyron is alsome would take it for sure watch the top gear review as well looks hot on the road
And its 4WD 1000hp plus RWD would have to mean wheel spin at 250kph
Edited by blk180
Howso? The Saleen S7 is a custom built car, and the twin turbo happens to be a factory option that gets fitted when the car is built by its OEM.
That's like saying an N1 spec GT-R is an "aftermarket upgrade" because it doesn't have the ceramic turbos etc of the regular GT-R.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
