  • Replies 40
I doubt the Saleen would have the handling or braking package that the Bugatti has. Could the Saleen box handle the grunt? The tyres? Bugatti has looked at these issues and had the dollars to support the R&D. Naturally time (and customers) will tell if they got it right. I think the Bugatti would have more visual impact driving around than the Saleen whose shape has been around for years.
I'd choose the Bugatti.
Edited by writeoff
It's easy to beat 400 in a straight line (well relatively ;-)
Put them both on the Nurburgring and see who wins over say 10 laps.
My money is on the Bugatti
True, Americans only know how to make their cars go fast in a straight line still.
Yes, the bugatti is not just a 1000hp 4wd silly car
It really is a true push the limit of technology and physics pure racecar
Its basically a formula one equivelant road car with a warranty and reliablity way past 2 races :)
Yeah you could build a 1000hp GTR for 1/10th the price. But it would never be the same as the rediculously engineered veyron
It has set a benchmark that no company can reach, not without a billion dollars and the equivelant 7 or whatever years of development
And by then, they will have updated the veyron even more
Its basically a formula one equivelant road car with a warranty and reliablity way past 2 races ;)
You're right.
Because Volkswagen wanted to commemorate their rich F1 history, by building a car that weighs over 2 tons (which says "F1 technology" to me).
It will be a true, BEAST.......... .... ... when it gets released!
haha
Have a look at this page
http://www.bugattipage.com/ride.htm
On another note, how often do you think you will be cruising at 400km/h in Australia. This car is way too much for Australia, specially on our crappy roads. Give me this in germany, AUTOBAHN BABY!
From that webpage
EPA city driving: 7 mpg = 40L/100
EPA highway driving: 10 mpg = 28L/100
Steady 253 mph: 3 mpg = 95L/100
Now stop whining about your bad "13L/100" fuel economy! hahahaha
You're right.
note the word basically mate :P
and considering its faster than ferrari's 2005 spec F1 car AND weighs more than 1400kg more than it ...
Faster in a straight line only.
U will have to take the thing to a place like NT to get close to even 400 licks here in aus.
I think linsay fox has ordered one for his car museum here in vic so we might get to see one in person.
If they are only making em left hand drive like the carrera gt and enzo then we won’t see them on the road here in aus anyway.
i don't know how much of you know they Saleen, for those who watch top gear and some discovery channel show which reviewed all the current supercars, you would know that the saleen S7, not this new one, but the current one, can hold its own weight in down force. It can literally drive up-side-down apparently. It doesn't need 4wd because it has also been well designed.
People who read Jeremy Clarkson's review of the veyron would know that its top speed cuts down to about 340 or 360 (can't remember exactly) when the wing is up, otherwise it would be wayy too dangerous.
I'd take the saleen.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
