Hey guys, just bought myself a 1993 r33 gts-t in what I thought was mint condition. It looked great, sounded sweet with the hegh flow cat and 3" cat back hks exhaust. It wasn't till I got it home that I found out the knob 2 owners ago had overboosted the standard turbo and melted the wheels. I had to pay a bucketload to get new steel wheels, new housing, and wastegate actuator and while I was at it I got it high flowed. Next came the dump pipe. It was at that stage I found a massive power loss at about 4500-6000 rpm. After exhaustive search on the net and lots of trial and error i found out the AFM was shot. Thats getting fixed now and I have run into my next dilemma, WHAT TO WASTE MY MONEY ON NEXT...
I know I need a fmic but need to know what is best and on the cheap having spent way too much already.
Is bar/plate better or tube/fin design. I also want to do the install myself as my mech "friend" has already taken about a month to get everything sorted (In total I have only driven the car for about 2 weeks and am sick of my POS ford laser).
Any suggestions would help.
My mods are:
High flowed steel wheel standard turbo
3" stainless dump pipe
High flow cat
3" HKS cat back exhaust
Turbosmart Boost controller (only running standard boost until afm fixed)
All the rest is standard atm.
https://www.sau.com.au/forums/topic/99114-whats-the-best-cheap-fmic/
There's nothing wrong with the hybrid copy intercooler. Pick one of those up for approximately $170 delivered to your door step and then take your selection at a piping kit which would cost you a further $350 or so. Either that or look on Ebay for some of the packages they offer
i like these coolers and piping.. there hybird coolers.. custem made pipeing.. give them a call!
http://www.advancedjapautoimports.com.au/intercoolers.html
Edited by DriftSquad
You had the turbo "highflowed", then fitted a decent dump and at that stage this power loss occured between 4500-6000rpm.
How positive are you that the cause is the AFM? Because it sounds like a textbook case of the ecus rich and retard strategy.
Did you try turning the boost down? Did it still happen?
Thanks for the info guys.
I am 100% positive it is the afm cuz the problem disappeared when I borrowed a mates s1 afm.
Boost is currently at standard.
I only noticed this problem after getting the turbo done because it was so badly screwed, especially the wastegate bleeding boost thanks to the busted actuator.
Gtr coolers are ridiculously overpriced for what they are imo. Just like every other gtr part. I mean, sure, it's proven that it's OK.
BUT why buy a gtr cooler for 250-400$ which could be a 15 year old POS when you can buy a 2nd hand apexi cooler with the 90degree return bend for like $350 (I've got one).
be careful, some cheap china kits wont fit in skylines.
I had one which had instructions to bend bits of the chassis to fit the piping. err no lol
I also have heard some horror stories like that. Dodgy kits that dont fit except if you cut and bend things are not my best choice. Heard of some guy who had to cut up his fan to make it fit. Not a good idea. Also is it worth getting a forward facing intake plenum or are they a waste of money?
Hopefully I will finally be getting my baby back today. I miss her so much even though she was almost as slow as my laser (I got beaten by a magna sports!! argh). Have to smoke my mate who owns an 88 supercharged mr2. shouldn't be too hard, hehe.
I would keep an eye out for better quality but second had kits, I got a HKS cooler plus piping for $600. Admittedly that was no cheaper than some of the hybrid copies but I was really patting myself on the back when I was able to fit it in around an hour due to the fact that every part was absouluteley mm perfect
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
