Whats The Best Cheap Fmic?
the_barman82
 Share
Hey guys, just bought myself a 1993 r33 gts-t in what I thought was mint condition. It looked great, sounded sweet with the hegh flow cat and 3" cat back hks exhaust. It wasn't till I got it home that I found out the knob 2 owners ago had overboosted the standard turbo and melted the wheels. I had to pay a bucketload to get new steel wheels, new housing, and wastegate actuator and while I was at it I got it high flowed. Next came the dump pipe. It was at that stage I found a massive power loss at about 4500-6000 rpm. After exhaustive search on the net and lots of trial and error i found out the AFM was shot. Thats getting fixed now and I have run into my next dilemma, WHAT TO WASTE MY MONEY ON NEXT...
I know I need a fmic but need to know what is best and on the cheap having spent way too much already.
Is bar/plate better or tube/fin design. I also want to do the install myself as my mech "friend" has already taken about a month to get everything sorted (In total I have only driven the car for about 2 weeks and am sick of my POS ford laser).
Any suggestions would help.
My mods are:
High flowed steel wheel standard turbo
3" stainless dump pipe
High flow cat
3" HKS cat back exhaust
Turbosmart Boost controller (only running standard boost until afm fixed)
All the rest is standard atm.
There's nothing wrong with the hybrid copy intercooler. Pick one of those up for approximately $170 delivered to your door step and then take your selection at a piping kit which would cost you a further $350 or so. Either that or look on Ebay for some of the packages they offer
You had the turbo "highflowed", then fitted a decent dump and at that stage this power loss occured between 4500-6000rpm.
How positive are you that the cause is the AFM? Because it sounds like a textbook case of the ecus rich and retard strategy.
Did you try turning the boost down? Did it still happen?
Thanks for the info guys.
I am 100% positive it is the afm cuz the problem disappeared when I borrowed a mates s1 afm.
Boost is currently at standard.
I only noticed this problem after getting the turbo done because it was so badly screwed, especially the wastegate bleeding boost thanks to the busted actuator.
Gtr coolers are ridiculously overpriced for what they are imo. Just like every other gtr part. I mean, sure, it's proven that it's OK.
BUT why buy a gtr cooler for 250-400$ which could be a 15 year old POS when you can buy a 2nd hand apexi cooler with the 90degree return bend for like $350 (I've got one).
be careful, some cheap china kits wont fit in skylines.
I had one which had instructions to bend bits of the chassis to fit the piping. err no lol
I also have heard some horror stories like that. Dodgy kits that dont fit except if you cut and bend things are not my best choice. Heard of some guy who had to cut up his fan to make it fit. Not a good idea. Also is it worth getting a forward facing intake plenum or are they a waste of money?
Hopefully I will finally be getting my baby back today. I miss her so much even though she was almost as slow as my laser (I got beaten by a magna sports!! argh). Have to smoke my mate who owns an 88 supercharged mr2. shouldn't be too hard, hehe.
I would keep an eye out for better quality but second had kits, I got a HKS cooler plus piping for $600. Admittedly that was no cheaper than some of the hybrid copies but I was really patting myself on the back when I was able to fit it in around an hour due to the fact that every part was absouluteley mm perfect
JustJap for the Hybrid Copy IC
JustSR for the Intercooler Piping Kit
Cost me $570.00 delivered in parts; friend got this package the other week for $550.00
Installation, DIY (much cheaper) :cheers:
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
