hey fellas :)
when ever i turn corners at low speeds, like always :cheers:
i get a tuk tuk tuk tuk tuk right through the whole corner coming from the diff, i been quoted that it is a aftermarket lock diff?????
Bel garage took it for a drive and said its ok, nothing wrong?????
but when the car warms up there is no tuk tuk tuk tuk sound at all?????
Steering and traction is all normal......nothing wrong there
Its an R32 GTS-T
Any help would be much appreciated :):O:O
https://www.sau.com.au/forums/topic/99141-what-kind-of-diff/
i been wanting to clear things up as a few people did not know what it is, i had an idea and though, yeh its a mech diff, but wasnt too sure.
Yeh that sound is awesomeeee, i love it wen people are like wtf his cars fuc#$@ lol
Can get a little annoying at times, but overall it sounds like a racer :cheers: and is mean hehehe
How can i find out the name of the diff??????????
i wanna know wat kind it is, as i bought it of the bloke and he didnt tell me anything about it :S
hey fellas :)
when ever i turn corners at low speeds, like always  :D
Its an R32 GTS-T
Any help would be much appreciated  :D  :D  :D
Sure sounds just like my one-way Cusco mechanical LSD (which is up for sale). Should only happen at slow speeds, light throttle and at tight corners. Over about 60 kph under full power should be quiet. Also, if it's a one-way diff it won't happen on the overrun or in reverse. A two-way or one and a half way may make a noise on overrun as well but these diffs usually lock more gradually and are therefore less noisy on the whole.
Try rotating the back wheels in the same direction when the car is up on the hoist and see what happens.
  • 1 month later...
Hello,
Sorry to hijack the thread, just a few questions. What is over-run? What type of mech diff would it be if it locks up and clunks going slowly in a corner (and up to about 50-60 in a tight corner), slow turning, and slow/fast turning from a stand still (from anywhere between half turn to full lock) and also turning while reversing (also from anywhere between half turn to full lock)?
Hope that makes sense?? :huh:
What type of oil would be best to loosen it up so its less tight and noisy?
This clunking is extreme, makes the ride extremely rough when it does clunk and its very loud too, i dont know which is louder, the clunking or the exhaust, it can be felt throughout the car.
Cheers! :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
