Thanks for the info , sounds like the 4wd would be a great solution to the lack of traction I have off the line. I took the car to the drags and the best I could do is a 14.2 with heaps of wheelspin, the 60ft time was shocking.
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1806732
AWD cef is pretty much the exact same as an R32 GTS4. Diff front, rear and ratios are also identical between the two. You can't mix and match manuals with autos though due to different diff ratios (well you can, but you need to make sure front and rears are the same).
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1806749
I did spot a factory special with RB26 and full GTR running gear , not sure if it was Autech model, I think it was a 96.
Pity no one complies the late models, I try to track down some pics.
Fuark.
That'd be worth it under SEVS no?
Can you just pick up the running gear into a RWD cefiro? I would have thought a AWD cefiro would have a different floor pan no?
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1811644
it does indeed, different chassis structure. I haven't heard of this autech RB26DETT ceffy till just then, but it won't be eligible under SEVS for sure (just like the Autech 4 door R33 GTR's and S15 convertibles aren't, until they are tested).
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1811672
  • 1 month later...
I'm plan to install the 4wd to my '89 A31 & will be RB26dett BUT dont know which rear assy to choose & other part. Recently I'm using RB25det S2 .
My idea if mod this RB25det engine with rwd, I will facing the traction problem.
Any idea & advise please
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1897012
mmmmmm autech 4 door R33 GTR........drool.
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1917828
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
