  On 20/03/2011 at 12:44 PM, Galois said:
I'm as sure as I can be of the day, I was a little shaken as it's honestly the first bad experience I've had being pulled over, but I pulled over soon after to remember as best I could and document the event. I would be far more specific in court, but i figured readers on here don't need to hear my detailed, obviously one sided arguments.
If there was ever a time to record a conversation, that was it.
I know that there would be very few police that would abuse their powers, intentionally anyways, but rb25 what would you do if you felt you were unfairly punished on the road? Or is there little to no tolerance for police off duty?
If it was alleged that I did something to which I know 100% I didn't do. Then I'd be fighting it. You can request to see the ICV (in car video); not immediately, but the next day or some days later back at the station. This saves you going to court. This of course only helps if the offence is caught on camera, which is not always the case.
Before I joined the cops I always thought it would be futile fighting fines in court as the judge would always believe the police. The best way to get a grasp of all of this is to go to court one day and just sit in and watch the cases. Opened my eyes a lot... it's a local court so anyone can just go in and sit there.
  • Replies 188
So how much do they pay you to trawl this forum?:whistling:
To be fair ^ ^ ^, I believe John is quite constructive.
He isn't the only copper on SAU. There are a few who are open about it.
And so long as they have a "We..." attitude, rather than a "Them Vs Us" attitude, it's good to converse with together.
BTW, this attitude ^ ^ ^ goes for us too.
Terry, i was not serious about my question. I was joking, it's called humor.:thumbsup:
  On 20/03/2011 at 1:55 PM, rb26zed said:
This statement just shows how little you actually know about the system.
I'd say that it was a comment made by someone who hasn't NEEDED a lawyer to represent them in court. The value of lawyers is only going to be known to people who have required legal representation.
good information in this topic i would just like to add my 2cents. i have found if you treat a cop like a persion and not a 4 letter word for male genatela. then he/she will treat you in the same lite give and take if you will. wont always be the case but hey better to be the biger man and stay calm cool and collected.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
