Last week I had my GTR tuned on Boost98 for a dyno figure of 351rwkw.I used Boost98 after reading the article in HPI by Martin Donnon.
The car ran great with knock readings in the mid 30's,till the weather got hot,where I recorded low 70's.Nigel(Ice Performance) suggested we retard the timing 2 degrees and see what happens.Single digit knock,so we tried 1 degee retarted,where we got mid teens and left it there.The car is going back in for cam timing adjustments,so I just adjusted the timing in the settings screen,I had to do it every time I restarted the car.
Today,I was near a Shell servo that stocks Extreme100,so I thought I would fill up(47 litres) and test it out.I am now running 3 degrees advanced over the original setting on Boost98,thats 4 degrees more timing!!!!! and recording mid teens on the knock sensor.
I will be using this fuel on my next tune in the New year,highly recommended.
Between now and my next tune,I will try Ultimate to see how it compares.
https://www.sau.com.au/forums/topic/99217-boost98-v-extreme100/
There are 2 Ethanol fuels.E10 has 10% and is sold by United as Boost98 and E5 has 5% and is sold by Shell as Extreme100.
Dyno figures are bound to go up dramatically as we had 365rwkw and had to knock out some timing using the obviously inferior Boost98.The 100 octane Extreme looks very very promising,allowing 4 degrees of extra timing while keepoing the knock lower,should also allow a little more boost.
which shell servo was this m&m?
Cnr Warrigal Rd and Centre Dandenong Rd Cheltenham,near DFO.
There are 5 shell servos on Burwood Hwy and 1 in St Albans as well.
thanks for that.
burwood hwy is a bit out of the way for me, so i'll have to try my luck in st albans.
Generally you loose power with ethanol blended fuels, so you have to advance the timing to get some of the power back. The good thing is, with careful tuning you can get good gains over the regular 98 RON stuff.
New 100octane shell fuel with 5% ethonal is what you want. you will not lose any power , you will gain timing,response and power.
I did some research ito fuel octane and detonation and have to wonder why the ethanol was added . I sort of though that the alcohol helped to make any condensation soluble but I'm beginning to wonder if slower burning high octane fuels need a bit of help at the cold start phase . The mighty 3 cyl G11 ran like a hairy goat at the first cold start on the Shell 100 but runs fine on it now . If anything it make a little better part throttle torque and the choke (showing its age here) is never needed .
It will be interesting to see if the other flavours of 100 octane fuels will have ethanol in them .
Cheers A
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
