what ever man the 1jz are awsome engines! they can handel 500kw and the 2jz can handel up 2 800kw on stock internals. 1 of my mates has a big T78 set up on his supra makeing huge power! i say go for it! not many conversions like that around id love to see how u go about installing!
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1807371
mr Eps, I assume you don't live in melbourne, where you have your car inspected only once and never again for as long as its in your name, unless the police ask you to.
Its a common swap, and done because those engines are readily availble in those countries, unlike the RB (the closest they get to an RB is the RB20E which is an SOHC 2.0L N/A and the RB24S which is an inline 6 carby engine). With this in mind, its easier to do an RB25 or RB26DETT swap in a cef, however the 1JZ and 2JZ swaps are doable.
You'd best be asking on a thai ceffy forum like http://www.cefiro-thailand.com
or
http://rcweb.net/forums/forumdisplay.php?f=31
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1807624
Thankyou :rofl:
The car would be engineerable (is that a word ?) wouldnt it ? I assumed it would be the same as putting an RB25 in.
or
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1808398
well im from perth and to the best of my knowledge (correct me if i'm wrong please) but i think it's un-engineerable (is THAT a word?) to have trans build engines in
like you can't put a lada niva motor into a mitsubishi lancer,
nor can you put an engine in that is older than the car's build date
ie: V35 skyline can't have an RB transplant etc,
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1809283
over here you can put any engine into another as long as it meets ADRs, then an engineer will have to sign off on it to certify that the swap is legal. Usually costs about $500 - $800 to get done. Once that's done then the car is legal with that engine.
The other way that most people do it is rego the car with the engine its supposed to have in it, then do the swap. Engine swaps aren't a roadworthy issue, so the roadworthy shops won't care. It is illegal, but it happens a lot in VIC. The only time you can get caught out is if you have a cop go through your car, or you go to resell it and it needs to go through the registration process again.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1809759
Yeh that was my understanding too. That you just have get an eng cert.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1810505
Removing the Toyota markings from the surface, whos to know its a Toyota motor at the pits? I think is definately doable....
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1810525
if you guys remember that Ferrari Enzo kitted 180sx that was on the J-Spec mailing list, it was bought by a guy in Syd who was gonna put a worked 2jz (out of his old silvia) in it.
https://www.sau.com.au/forums/topic/99218-1jz-into-ceff/#findComment-1812924
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
