Hi does anyone have pin outs for the following plug many thanks r33 gtr rb26dett
Thanks for the reply. Not getting voltage from the pin that connects to the map lights. https://www.dropbox.com/scl/fi/9nbsakvhdo6gjtv713dk6/Photo-Sep-11-2024-10-40-27-AM-2.jpg?rlkey=8bh4lx8ei639tde4eepveqgpg&dl=0 https://www.dropbox.com/scl/fi/rhtt0kxmgzxiwh7re22ij/Photo-Sep-11-2024-10-40-27-AM-1.jpg?rlkey=zecek0bzrxj6714tyk6x8te5v&dl=0 https://www.dropbox.com/scl/fi/cfhsp62058y3ittmkes8n/Photo-Sep-11-2024-10-40-27-AM.jpg?rlkey=tfixv4tvs6ko9ao41q6e62gwr&dl=0 couldn’t insert images from my phone so here’s Dropbox links
Have you finished making it? Tempting offer if you are still making more, might be worth also posting in the M35 Stagea tuning group on Facebook.
By TurboTapin · Posted
My comment was aimed at the mention of possibly using hydraulic lifter based cams with solid lifters. I make a lot more then 600hp. It has nothing to do with power. Cam/Lobe profiles differ between hydraulic and solid lifters. Kelford stated their hydro lifter cams cannot be used with solid lifters. Kelford will probably recommend their 244-A2 cams for your goals. Cheers. -
Will the two valve cover pcv fittings rotate? I believe they are pressed in. I am wanting to rotate them to reroute the hose that currently connects the two.
