94 Lancer Gsr
1994 mitsubishi lancer gsr
Harlequin green 2 purple paint job
Full evo 3 body kit including fibre glass bonnet
Clear tail lights
VR4 2 ltr conversion done by RX ENGINEERING
5 speed manual
300x600x70 Front mount intercooler
11"x8" oil cooler
Microtech lt10 computer
3" exhaust turbo back with cannon
POD filter
Turbosmart type 2 BOV
Turbosmart bleed valve
Walbro 500hp fuel pump
Strut brace
Exedy heavy duty clutch
Monroe Shocks
King springs
Slotted front rotors with EBC green stuff pads
18x7.5 lenso versud rims
Autometer boost gauge
Momo steering wheel
JVC mp3 player with 6" splits, 6x9's, 2x12" subs and an amp
Car is in excellent condition and runs extremely well. Recently dynoed 180kw @ the wheels.
Selling with rego until 22/10/2006
$25,900ono
ph: 0438773901
email: [email protected]
 Share
    • I'm looking at it now. The price dosent seem that bad.. a new R32 GTR AC compressor is $500-600 here in the states. It looks like they are using a different compressor though from a Toyota Echo.
    • Does yalls AC work?
    • There's a few other differences between S1/S2 that you will have to deal with, including either using an S2 coil pack harness or modifying your S1 coil harness to bypass the igniter. So short answer to your question, just buy an S1 ecu. They're probably giving the things away now. Long answer to your question, yes it can probably be done, but refer back to short answer for best option. I would never use an RB25 ECU to run an RB20.  Cheers,
    • So there’s no issue.   I can use s2 ecu on s1  or rb20? With factory igniter setup right?
    • Your engine won't shut off with ignition if your MAF is unplugged? I want to confirm I'm reading that right.
