I'm about to go out and murder some little local pr*cks.
My holiday/ fishing vehicle (2005 hilux SR dual cab) loaded up with expensive fishing gear and hunting equipements was half packed for Friday and I did the cardinal sin, by taking it to work to get tinting done.
Well the little bastards smashed the driver side window and mangle the rear right door trying to openin the ute up, in the process they threw a brick through the window so hard that it smashed the centre console and destroyed the door trim on the otherside.
The police didn't even wanted to know about it after I waited for nearly 2 hrs at the local cop shop.
Now I finished my rant, anyone see any young kids running around with VERY expesive binnoculars/scope please contact me,a big reward is offered.
https://www.sau.com.au/forums/topic/99230-vehicle-broken-into/
OOps, sorry, the area was Calamvale. I suspect the gear would be floating around Browns plains/Crestmead area, as I've seen a few youngins walking towards that direction this morning.
More than likely. Prob the stupid barsard round here that got pulled over trying to steal a bobcat the other day.
Hope they are caught, and you get most if not all your gear back.
Out of interest, insureance???
even if u got insurence most of em only cover upto $300 of gear inside the car.... unless u want to pay more for your insurence :)
Yes the car was insured, but personal effects is $300 max, DOH!!
To make matter worse, Toyota haven't got one of those side glass in stock, and I sat on a glass splinter yesterday which will need the attention of my good looking female Dr.
So the trip out to St. George is off, oh well I be doing somethig else this Xmas.
yeah I know with the insurance been there done that lost over $1000 worth of gear out of my old surf, makes u really want to find the turd that did it & snap there fingers off one segment @ a time
hope u still have a good xmas bud B)
Sorry to here that champ
in a way xmas is the shitest time of year
brak ins
angry cusumers
i had my laser broken in to last friday
$6000 worth of stuff gone so i feel for u mate and 2 days later i put my skyline into my brick piler doen $2000 damage come in 3s
james
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
