Keep My Neo 25t Or Get An R33 25t?
DRFT 14
 Share
I’m in a bit of a predicament with my NEO RB25DET. I bought an 80000kms neo engine with the plan to drop it into my S14 Silvia (previously fitted with an RB20DET which ran a bearing). The motor is missing its ECU, AFM and wiring loom is cut. I’ve spent the last couple of weeks trying to hunt down those parts to no avail. The only person I found that had an ecu wanted $400 for it. A wiring loom would have been easily over $600. I can’t afford this kind of cash and it’s making me regret going for the later model NEO engine. I’ve been getting laughed at walking into wreckers and asking for NEO parts, they are too rare at this point.
This brings me to my question and the reason I started this thread. Should I make my life easier and re-sell the NEO 25t and just buy a 100% complete 25t from an R33? This will save me a lot of headache and money, but I’m afraid I’ll regret this decision later on if do go along with option B. But is it worth the hassle with the neo motor, in regards to the improvements in the NEO head? Does it really make that much of a difference? I’ve heard that the reason the R34 has 30hp extra over the R33 only because of a boost increase. Does that mean that the neo head does nothing to increase power? I’ve got a 500hp T3/T04e awaiting fitment on the motor (along with many other mods-FMIC, Walbro, manifold etc). Will the neo motor spool the turbo up quicker or will there not be an advantage once the turbo is fitted and the motor is tuned (between the r33 and r34 RB25DET)?
Your thoughts as usual very much appreciated. My heart says keep the Neo motor, my wallet says sell up and get an R33 25t, what do you guys reckon?!
Edited by DRFT 14
go for the option b and get a 33 25. more parts from wreckers available as you know and generally more stuff for sale on here for them also. If your gonna chuck a bigger turbo on it, it will spool up much the same on the neo as it would the plain 25t. The differences your talking about here are bugger all. If it were a 26 or 25/30, 26/30 you comparing it too, then shit yeh we would say u would be insane to sell up. Overall the cheaper it works out to be, the more money you will save in the long run to spend on other things for the car.
Agree on CR with jim.
I can't believe you can't find a manual ECU cheaper than that. How many people on this website have upgraded to a PFC. They would sell you there old ECU for $100 no worries I reckon. Put up a wanted to buy thread.
That said, the stock ECU wont be able to handle what that turbo will put through it so it will need to be chipped or you need a PFC anyway. Whether you go R33 or R34 you still need a pfc or equivalent.
The NEO head should definitely be a little better than the R33 but you are hamstringing yourself with that old turbo.
It doesn't get the extra power from extra boost. Both are 7psi. It gets it from different head (solid lifters, different cams etc) better ECU and a larger exhaust housing on the turbo.
As for the loom, you either have to make one up or bite the bullet and buy one. Whoever buys your engine should you choose to sell it will probably talk you down based on the fact that you have no loom if they are doing a conversion. I looked at buying a second hand motor when I blew mine recently but the cost v cost of a rebuild makes it not worth while and this is the only situation where a buyer wouldn't need the loom.
i think if you don't have the loom, or the ECU the you have a blessing in disguise. I would do straight for something like a mircotech, or autronic, or wolf or similar. Get a good installer to wire it in (it's not that hard). i think it will work out cheaper in the long run, plus you have a tuneable aftermarket computer straight off the bat.
failing that (try and) sell the neo and buy a garden variety R33 RB25.
I have looked into the aftermarket wire-in ecu idea but was not sure if the these products fully replaced the standard wiring loom or simply spliced into the existing nissan wiring loom. I actually started a thread asking this question but didnt get any useful responses. Maybe you guys may know the answer? My Neo motor actually has all the sensors and wiring on the head intact. Its simply cut from around the alternator wiring side (I got a replacement for that part) and chopped where the thick coil begins to route into the firewall and plug into the ecu. Does this help in relation to wiring up an aftermarket ecu?
I know you guys dont like LINK, but im in NZ and can pick one up (with wiring loom) for $970.
didnt you already ask about this before , im sure ive already replied
If you get a WIRE IN aftermarket ECU , like a haltec , motec , autronic , EMS , Microtech or link you will wire it into your motor . You do not use the factory loom (although to save time/money you can adapt the existing loom) . Also all these ecu's use a map sensor so you do not need the AFM
the easiest and best solution is to get a wire in aftermarket ecu
Thank you very much, made my day. And sorry, i didnt see your reply on the thread. $970 will now sort three things out at once- AFM-gone, ecu and wiring sorted.
Il call LINK tomorow morning, if what your saying is correct (im sure it is), then looks like the NEO is staying :P
howdy i jus found a r34gtt (neo) computer and other shit on ebay... its only got 23 hours left on it with no bids... offer him a hunj for the computer and he might seperate the stuff... $90 shipped to nz... heres the link anyway... take it or leave it cheers...
http://cgi.ebay.com.au/R34-SKYLINE-COMPUTE...1QQcmdZViewItem
you can adapt a r33 powerfc to the r34 neo
but he doesnt have an engine loom
if he did could get a r34 power fc
aftermarket ecus do take more work to get them handling factory idle/coldstart/aircon control but it can be done and done extremely well . its all down to your tuner and how much money you can throw at him to tune it.
Edited by arkon
 Share
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
