Neo,
Ive used rear R31 wheel studs(5 mm longer than the stock ones) in my dato 1600.
Im pritty sure that most if not all nis/dat wheel studs are interchangable.
As for the TRX wheel nuts, You can either go to nissan and pay $8 per wheel nut or go to the wreckers and pay about $5/10 for a set.
The wheel nuts that are used on bluebirds with factory mags are the same as the TRX nuts.
Hope this helps.
Cheers,
yeah.. nissan don't stock them any more, I'm going to go to a wrecker and go through boxes of wheel nuts.. just can't get them anywhere. the 5mm longer studs might mean a normal tapered nut can get s grip on the bastard though. and if they go straight in then brilliant. pity they're $8 each or something :)
