Hi all,
I am considering getting some new wheels which will sit inside the guards a bit compared to my current rims (about 1cm extra inside). I believe this will reduce the track of each axle, but how does track affect handling? i believe it affects body roll.
is the difference only theoretical or will it actually be noticed
Thanks
Greg
my suggestion is if they are offset 10mm differently to your current rims, then just run some 10mm spacers and you will be back where you started :)
10 mm track each side, so a total track recuction of 20mm. i don't know if it would be noticeable, but more track is certainly a good thing.
at the risk of being accussed of always disagreeing with everyone, more track is not always a good thing. changing track affects your scrub radius. too much and it can make the car darty under brakes and reduce the outright cornering power of the car. Now I haven't had a good look at scrub geometry on the Skylines to say what will be better, but it is likely by going closer to standard scrub geometry you will be improving the situation. Will it be noticeable? hard to say - depends on alot of factors, and like everything some cars are more sensitive to this than others. But I wouldn't expect it to be noticeable on street tyres.
Hi all,
Thanks
Greg
My 20 cents ........
That small a change in track is not worth worrying about on the road. You won't even feel it.
:) cheers :spank:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
