Item: 1992 Nissan Skyline R32 GTST
Item Condition: Excellent
Reason for Selling: Upgrading to an r34 or something else.
Price and Payment Conditions: $16,000 neg.
Extra Info: Manual, White with Black Roof, Sunroof.
Contact Details: 0433-100-301 / [email protected]
I am selling my modified r32.
Exterior:
White body with black roof and carbon bonnet with GTR front grille.
Assortment of wings to choose from (GTR wing and boot lid lip spoiler) currently
there are no wings on the car.
Bomex front bar
GTR Side Skirts and rear pods.
Electric Glass Sunroof (works perfectly - factory item - tilt & slide)
R33 GTST brakes all round - slotted and drilled rotors on the front.
Tein HR coilovers
Front and Rear sway bars.
Unmarked interior with black recaro bucket seats.
Cusco 2-way LSD
3" exhaust from the turbo back.
RB20DET engine
Aftermarket aluminium radiator with thermo fan.
R34 GTR Front Mount Intercooler
Pod Filter
Catch Can
GTR 444 Injectors
Denso high flow fuel pump.
LINK aftermarket ecu (full replacement / no piggy backs)
HKS Electronic Boost Controller
Excellent condition inside and out - regularly serviced/maintained/modified by
Amberley Autos
DriftLine Racing
I have got an rebuilt T28 rollerbearing turbo that i can sell with the car. With this turbo on the car it has reached 210rwkw on 18psi of boost.
I am negotiable on price.
Edited by aKTiVE
https://www.sau.com.au/forums/topic/99293-for-sale-1992-r32-gts-t-modified/
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
