basically i have a way i can get positive pressure up to about 7psi into my non turbo R34 RB25DE neo engine. however if it hits that, the ecu cuts out and the engine stalls.
i want to obviously run +boost.. what do i NEED to get so i can run that positive boost im SURE the fuel pump + injectors can atleast handle 3-4psi because i mean common i doubt they would put in factory items which are basically 'maxed out' from factory. so im guessin its the AFM or ecu .. maybe both
so what do i need so i can hit boost :P
https://www.sau.com.au/forums/topic/99304-what-do-i-need-to-make-my-nonturbo/
I had the same issue trying to run the RB30DET on the rb20det ecu.
At around 7psi or so a fuel cut would occur and it would go dangerously lean.
Only option is a remap or aftermarket ecu as the std maps don't have the head room.
Edited by Cubes
My method of generating positive pressure (hehe) is driving really really fast with a 500mm dia snorkle in front of the radiator that tapers down at a 12.5degree angle to 80mm dia, this then feeds in to the afm (mesh removed to reduce pressure drop) then directly in to the cross over pipe. ;)
:P
Edited by Cubes
  • 1 month later...
