nissan_gtr35 Posted December 22, 2005 Share Posted December 22, 2005 (edited) Hi All, Im having some isues with my car currently and i was after some advice. The problems i am having are as follows: 1. Fuel Pump is making an audible whirring noise and has done for some time 2. Car is guzzling fuel even on the highway (best i got was about 12L/100km over a 1000km stint and it was reasonably hot day at about 35 deg) 3. The exhaust note of the car has changed significantly recently and it now burbles alot like a WRX does. Car type: R32 gts-t Current mods include: pod filter, BOV, hybrid intercooler. Still running standard turbo/boost. I have a sneaking suspision that my fuel pump is somewhat shagged but i was hoping that someone out there might have experienced something similiar and can lead me to the exact problem. Cheers Laine Edited December 22, 2005 by nissan_gtr35 Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/ Share on other sites More sharing options...
Beer Baron Posted December 22, 2005 Share Posted December 22, 2005 12l/100 kms could be great depending on what type of car you have... my GTR gets around 20l/100 kms. what car are you talking about mate? Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1809746 Share on other sites More sharing options...
lordsnipe Posted December 22, 2005 Share Posted December 22, 2005 i get just about 12.5L/100 kms with a mix of normal and hard driving in the city. I have a 33 gtst. Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1809753 Share on other sites More sharing options...
nissan_gtr35 Posted December 22, 2005 Author Share Posted December 22, 2005 Yeh car type would be handy hey!! R32 Gts-t it is! Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1809757 Share on other sites More sharing options...
GTshortie Posted December 22, 2005 Share Posted December 22, 2005 i get 12L/100kms for highway, 15-16L/100kms for city driving, thats a r33 gts25t, worked engine high boost, but babying it around most of the time, most import thing to note is 550cc injectors and nismo fuel pump Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1809813 Share on other sites More sharing options...
MR SLY Posted December 22, 2005 Share Posted December 22, 2005 check your coil packs.... looks like one of it has blown... that happened to mine... Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810496 Share on other sites More sharing options...
KamikazeR33 Posted December 22, 2005 Share Posted December 22, 2005 yeah i was gonna say sounds like shes running on 5 cyl... check coil packs (could b a loose plug as this happened to me once) Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810514 Share on other sites More sharing options...
nissan_gtr35 Posted December 22, 2005 Author Share Posted December 22, 2005 yeah i was gonna say sounds like shes running on 5 cyl... check coil packs (could b a loose plug as this happened to me once) <{POST_SNAPBACK}> Thanks guys. Checking them now but im not sure how to check the pack itself? Any ideas as to the best way to see if they are working? I have checked connections and they all seem ok Cheers Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810567 Share on other sites More sharing options...
predator Posted December 22, 2005 Share Posted December 22, 2005 i'd say its o2 sensor.. is it gurgly at take off? but on full boot not too bad? Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810580 Share on other sites More sharing options...
nissan_gtr35 Posted December 22, 2005 Author Share Posted December 22, 2005 Well ive checked all the ignition coils and it appears that the second one from the front is shagged. Thanks for your help guys much appreciated. Laine Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810760 Share on other sites More sharing options...
KamikazeR33 Posted December 22, 2005 Share Posted December 22, 2005 is there just a crack in the side of the casing? if so, get some electrical tape. seems to fix the problem Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810951 Share on other sites More sharing options...
kudos.motorsports Posted December 22, 2005 Share Posted December 22, 2005 My money is on a dead coil pack. Simply remove the valley cover and disconnect the coils one at a time while the car is idling till you don't hear a note change in your exhaust. This will atleast find the troubled cylinder. After finding this change the coil from a known working cylinder and see if the cylinder you swapped the coil from now has the problem. If so you have a coil pack that needs replacing. If this doesn't fix the problem remove the spark plugs from the troubled cylinder and check it. It that's fine then it's either your ignitor box or a blocked/troubled injectors. Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1810968 Share on other sites More sharing options...
nissan_gtr35 Posted December 23, 2005 Author Share Posted December 23, 2005 My money is on a dead coil pack. <{POST_SNAPBACK}> Yeh i tried changing them over and the bugger started working again. It appears to work when it wants too so i think i will get it replaced anyway. Anyone got one handy they want to sell? Laine Link to comment https://www.sau.com.au/forums/topic/99305-car-sounds-like-a-wrx-guzzles-fuel/#findComment-1811749 Share on other sites More sharing options...
