HELP! :):(
Got my car booked in next week for window tinting B) , through a group buy on this forum! But need help, I still can't decide which % tint to go with! Was thinking 15% but don't want to get defected and not sure about night visibility, on the other hand 35% may not be dark enough to keep the heat out and people from looking into the car!
Any suggestions and/or pics of recently tinted cars!? Are there any Series 2 R33 GTS-25T recently tinted out there?
Any help will be greatly appreciated!!
:D:(
https://www.sau.com.au/forums/topic/99335-window-tinting-15-or-35/
i have 15% on a R32 GTR, suits the car perfectly, visibility is good, and cant see in at night
I wasnt sure which one to go either, but greg showed me the 15% on a ceffie and im really happy with it
Thanks heaps guys!
I will probably go for the 15% and stay away from the cops! I will be seeing Greg next week and he will show me some samples but to be honest I was pretty keen on the darker tint. In the end it just seems to be better overall!
Once again, Thank you.
my sII came with tinted windows at the back ...i cant see shit out the back at night...day time is pretty bad too so i have to reverse using side mirrors only ..
Would you know what % the windows were tinted at? Chances are they would be pretty close to 15%, or maybe darker?
So since 15% is a defect, perhaps consider what ure insurance company will say if you have a smash. "your tints are past the legal limit, we think you could not see, bye bye payout"
You make a good point, the last thing that I need is 1) to have an accident and 2) to have problems with my insurer!
no its pretty hard... I usually have to turn down the windows... To get a better view....  :P
I don't really want to have this problem but it will prevent theives from looking into the car and the possibility of being broken into. Would 35% be able to do that? Obviously not as effectively, but within reason.
Thank you all for your input!
35% would help at night. but its not going to stop them from seeing thru.
I have a few mates with 5%. you cant see anything with the windows up at night. not sure about 15% though. im sure it wouldnt be much different.
yep 5% you cant see shit at night but i drive around with the windows down all the time anyways...
i love it... wouldnt have any less.. only have trouble when there arent street lights and if the street is really dark i cant see where im going.. but its all good
hey sup man.. once u get your tints done, please post up some pics.. would love to see how the car looks with dark tints.. so im thinkin of doin the same thing.. n i got same colour car as u so yea..
thanks man..
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
