Hi,
I have step 1 hks cams now, stock valve springs etc
should i put cam gears? before i get it tuned, do you think they are worth it? what gains will i get from them?
why would you buy cam gears? who sells cheap cam gears? ( honestly i wouldnt spend more then 150$per cam gear :) )
cheers
Hi,
cheers
Yep - cam gears are definately a good idea as they turn the camshafts which in turn activate the valves in the head.
One advantage of not fitting cam gears, however is that the valves, springs and cams will last a very long time (perhaps forever?) and require little if any lubrication.
Perhaps the biggest disadvantage of not fitting cam gears is that the engine doesn't run without them, although this is also an advantage if good fuel economy is a priority to you.
Nope...the valves will actually last about half a second
Sorry - can only have so much "Christmas Cheer" before something has to give!
Yep - the benefits of adjusting cam timing is well documented and makes a huge difference on RB26 engines. The cost of these can be dwarfed by the labour and dyno costs if you want to tweak the power vs mid range torque tradeoff to your exact liking.
As others have said - do a search as there is plenty written on where a good starting point is.
Good luck
Gav
Yep! get em. I have a set of pond cams and I gained 80rwhp 900 rpm earlier! after diling them in on dyno. but lost 5 hp at top after doing inlet, and actually got 10 more hp at the top after doing exaust, so I ended up gaining top end as well.
Os Giken $300 a set. = bargin.
who sells them for 300?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
