regret selling this car as it never get driven and just siting in my garage i bought the car brand new....spend alot of time and money on the car so it just a waste sitting in the garage car has only done 22000ks and its a 2002 model its been full repsrayed custom candy orange/copper colour
here r the mods
sunroof
hybrid gt frontmount intercooler
garrett 440hp hi mount turbo
oil cooler
256 tomei cams and cam gears
sard regulator
850cc sard injectors
greddy plenuem
greddy type r BOV
koyo radiator
tien HA suspension
tein camber top
r32 gt front breaks
surge tank
external fuel pump
half rollcage
swade blue interior
nismo strut brace
apexi exhurst
full cwest widebody kit
19in lenso wheels
kenwood indash tv
power fc
avcr boost controller
momo steering wheel
clear tail lights
hid headlights
brand new heavy duty clutch
whiteline sway bars
the car ran 12.8 at 1 bar of boost at 112mph and now with more power it should do better...the car is in top show room condition in and out..
asking for $39500...pm me if your interested..the car is also fully engineerd at the rta..will consider a trade for a s2000 depending on yr model number plates r not for sale
here r some pictures
http://i11.photobucket.com/albums/a157/vilain/VILAIN/9.jpg
http://i11.photobucket.com/albums/a157/vilain/VILAIN/1.jpg
http://i11.photobucket.com/albums/a157/vilain/VILAIN/12.jpg
http://i11.photobucket.com/albums/a157/vilain/VILAIN/10.jpg
Edited by Pro2835
https://www.sau.com.au/forums/topic/99361-vilain-s15-forsale/
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
