Skylines Suck P00py :p
ZOR
 Share
  • Replies 100
daveo, i'll happily meet you at QR in winter to show you what a 'fairly' stock R32 will eat your cefiro :nyaanyaa:
I remember this skidpan day we had. And I seem to remember the times, and I seem to remember my 'for lunch' cefiro being slightly higher up the peacking order :blink: LoL.
I have some funny feeling Im going to be paying for all this later.
Back onto the 300's. I forgot to mention another ghey aspect of their nature. You can't put big cams in them. Because of the poor design, if you put in cams with a larger lift the lobes hit on the head.
I WANT ONE!!!!!!!!!!!!!!!!!!!!!
LoL, my mechanic has made some REALLY good money because of someone did that! Out and in with the engine 4 times now I think. He was told by the engine builder not to put the cams in, so what does he do, puts the cams in. At I think $1200 a pop, hes paying for buying a 300.
he probaby got beaten on the highway by a skyline. have a cry mate!!!!
You have no idea who I am, or what my personallity is, or how comical this thread actually is. Its a fairly well known fact that for what my cefiro has (ie exaust filter, and a bleedvalve, no front mount etc) it goes pretty bloody good, but anything with a bigger turbo (ie rb25 turbo) is going to beat me. I just find it funny that its the same engine, in a lighter car, yet I end up in front.
Anyway, back to the 300zx things are the greatest and skylines suck topic, which is the orginal topic.
Hey Dave, I reckon my stagea and your ceffie would prolly be a good match up, I have a slow wagon and you have the weight advantage.... :blink:
Could be a number of things...  He had lost over 250points on his licence tho.  Might be something to do with the spur bill.
it's got nothing to do with SPER or selling stuff on the forums/ebay. he has been sentenced to 6 months and a period of good behaviour upon release.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
