okay...
Mechanical: The guage itself acts as the sensor... i.e. if you've got a Mechanical boost guage, the vacuum (boost) line will plug directly into the back of the guage, and this is used for the input for the readout...
Electrical: The guage gets its data from a seperate sender. I.e. in the example of a boost guage again, there would be a seperate sender mounted in the engine bay somewhere, that the boost line plugs into... the Sender then converts the boost pressure into electronic data, and transmits it to the guage, which then displays it for you...
So, in conclusion, if you're looking for things like Oil Pressure, Oil Temperature, Water Temperature etc, try and get Electronic, as nothing worse than driving along, and getting boiling hot oil squirted on your face if the line/guage fails or something.
(Well, thats my interpretation of things, someone feel free to correct me if i'm wrong)
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1811577
The only mechanical gauge I'd have is boost.
Another way to think about it is the gauge needs smething to detect what it's actually reading right? something that detects the temp/pressure/whatever.
In an electrical, the sender sits in the engine bay and sends an electrical signal to the gauge by a wire to tell it what value to display with the needle.
With a mechanical, you have to take whatever you're measuring and plug it straight into the gauge.. so your oil line has to go into the cabin to plug into the gauge. Ugly stuff.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1811659
anyone seen the price of electric fuel pressure guages??? they are like $900 from autometer...
and only $160 for Mech style fuel pressure...
so you definately pay for it. but the std ones like oil pres. and temp are still cheap for electric guages.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1813039
Cheers! thats pretty clear. i think that electric autometer one can stay in the shop. thats ridiculous. i also saw one that was liquid filled? whats the go with that. it sold for $60 on ebay. i thought that sounded like a sweet price.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1835336
Ouch. I would NOT pay a. for american gauges b. that much.
Greddy electrical gauges go for 180-200 second hand on the forums. Funnily I have a water one ready to go (black face) if anyone wants (shameless plug).
Nengun have them around $220-$280 brand new.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1836104
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
